Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D1.8/D1.8M: Structural Welding Code - Seismic Supplement.
 anfaga
structural engineer
User ID: 12412
Threads: 39
Likes: 606 in 50 posts
Given Likes: 279
12-28-2015, 05:12 PM (This post was last modified: 09-02-2023, 12:00 PM by Administrator.)
AWS D1.8/D1.8M:2005 Structural Welding Code Seismic Supplement.
Author(s)/Editor(s): American Welding Society (AWS) | Size: 0,82 MB | Format: PDF | Quality: Unspecified | Publisher: AWS | Year: 2005 | pages: 109
[Image: 90008810170380266428.jpg]
This code supplements the requirements of AWS D1.1/D1.1M, Structural Welding Code—Steel. This code is intended to be applicable to welded joints in seismic load resisting systems designed in accordance with the AISC Seismic Provisions. Clauses 1–7 constitute a body of rules for the regulation of welding in seismic load resisting systems. There are seven mandatory annexes in this code. A commentary of the code is included with the document.
[-] The following 16 users Like anfaga's post:16 users Like anfaga's post
  • blaze, Jackass, bridgeengineer, faros3000, RyanRS, oanm2000, Dell_Brett, gulilero, malc, PinkPant, psk62, avge, slowet, K.Lee, tuanpecc1, kowheng
 PinkPant
Turkey
User ID: 25448
Threads: 66
Likes: 4,006 in 374 posts
Given Likes: 10354
07-02-2016, 08:52 AM
Use regular forum pass
PinkPant
[-] The following 14 users Like PinkPant's post:14 users Like PinkPant's post
  • subin91, uncblue, milova, Dell_Brett, malc, oanm2000, f_slikken, K.Lee, Trishu999, Wijono, Hengki, Aviator, kowheng, blaze
 malc
User ID: 30599
Threads: 66
Likes: 1,520 in 155 posts
Given Likes: 15191
08-01-2018, 03:32 AM
AWS D1.8-D1.8M 2016 Structural Welding Code Seismic Supplement.
Author(s)/Editor(s): AWS | Size: 1.45 MB | Format: PDF | Quality: Original preprint | Publisher: AWS | Year: 2016 | pages: 138 | ISBN: 9780871718945
[Image: 09999163626539497550.jpg]
Damage sustained by welded steel moment-frame buildings in the 1994 Northridge earthquake, and extensive research conducted by the FEMA/SAC program following that earthquake, demonstrated that in order to obtain adequate performance of welded steel structures under conditions of severe earthquake-induced inelastic strain-ing, additional controls on design, detailing, materials, workmanship, testing, and inspection are necessary. This research resulted in substantive changes to the AISC Seismic Provisions, which control the design of steel Seismic Force Resisting Systems (SFRS) designed to withstand severe inelastic straining as well as certain aspects of the materials and detailing of these systems. The provisions contained in this standard complement the AISC Seismic Provisions and are intended to ensure that welded joints that are designed to undergo significant repetitive inelastic strains as a result of earthquakes, or that are used to connect members designed to resist such inelastic strains, have adequate strength, notch toughness, and integrity to perform as intended. This code, together with AWS D1.1/D1.1M, specifies the acceptable materials, procedures, and workmanship for constructing welded joints in SFRS designed in accordance with the AISC Seismic Provisions as well as the procedures and acceptance criteria for quality control and quality assurance inspection of welded joints in the SFRS. In some regions of the U.S., with low risk of intense earthquake shaking, building codes permit design of steel Seismic Force Resisting Systems that do not conform to the requirements of the AISC Seismic Provisions. The requirements of this code apply only to the SFRS in structures designed in accordance with the AISC Seismic Provisions and need not be applied to structures not designed to those provisions.
[-] The following 18 users Like malc's post:18 users Like malc's post
  • jcbv, rendel_©, zrilek, PinkPant, febo927, oanm2000, promo8, carolinandra, tuanpecc1, monter, Dell_Brett, faros3000, ascetic19, kowheng, blaze, kristoffer_89, jonygut, TAFATNEB
09-02-2023, 11:59 AM
AWS D1.8/D1.8M-2021: Structural Welding Code—Seismic Supplement
| Size: 9.2 MB| Format: PDF| Year: 4th Edition, 2021| pages: 148
The provisions of this code supplement the provisions of AWS D1.1/D1.1M, Structural Welding Code—Steel, and shall apply to the design, fabrication, quality control, and quality assurance of welded joints designed in accordance with the AISC Seismic Provisions for Structural Steel Buildings. All provisions of AWS D1.1/D1.1M for statically loaded structures shall apply to the designated welds, except as specifically modified herein.
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • babakfeyzi, jcbv, rami1976, PinkPant, subin91, kowheng, TAFATNEB
  AWS D9.1/D9.1M: SHEET METAL WELDING CODE poolmand 0 1,863 09-04-2023, 12:08 PM
  AWS D3.6M: Underwater Welding Code poolmand 0 1,394 09-03-2023, 04:54 AM
  AWS D1.6/D1.6M: Structural Welding Code - Stainless Steel poolmand 1 3,296 09-02-2023, 11:57 AM
  AWS D1.5M/D1.5: Bridge Welding Code poolmand 1 1,694 09-02-2023, 11:54 AM
  AWS D1.4/D1.4M:Structural Welding Code Reinforcing steel rami1976 3 2,819 09-02-2023, 11:51 AM
  AWS D1.2/D1.2M: Structural Welding Code - ALUMINUM poolmand 1 3,687 09-02-2023, 11:43 AM
  AWS D1.1/D1.1M: Structural Welding Code - Steel. anfaga 6 3,228 09-02-2023, 11:41 AM
