Civil Engineering Association eBooks Journals, Papers and Presentations MECHANICAL NONLINEAR SHEAR WALL MODEL
05-30-2014, 01:20 PM
Author: Tarun R. Naik,1 M. ASCE, Sandor Kaliszky,2 M. ASCE and Lawrence A. Soltis,3 M. ASCE | Size: 215 KB | Format: PDF | Quality: Unspecified | pages: 06
Shear walls play a dominant role in the static and dynamic analysis and design of low-rise timber buildings. Shear wall behavior is often difficult to describe. For example, low-rise timber buildings have shear walls made of lumber framing and various sheathing materials. The loaddeformation
plot of a shear wall, when subjected to horizontal loads, is
nonlinear. The analysis of a shear wall building thus requires either full-scale test or nonlinear analysis. Full-scale tests do demonstrate true nonlinear behavior; however, they are often too time consuming and expensive for the number of replications necessary for a statisticallyvalid study. Nonlinear analysis often involves mathematical complexity and instability such that limiting assumptions are necessary to simplify the problems. This study describes a mechanical model which simulates the nonlinear behavior of a shear wall and aids in the construction of inexpensive models of entire shear wall buildings. Static and dynamic measurements obtained using these models can provide reliable results for shear wall buildings. Tests on these wall models will be useful to: (1) Observe nonlinear behavior of the "parent"structure without having to conduct fullscale tests; (2) check the accuracy of linear analysis; and (3) verify the results of nonlinear analysis.
  • rezart, blaze, ting tsai huang, vardan, PinkPant, Mohammad6299, zrilek, ykhackhack, simanta, malc, ruaumoko
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,296 08-01-2017, 09:19 AM
Last Post: abdulazizk
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,593 02-12-2015, 01:39 PM
  Development of a Precast Concrete Shear-Wall System Requiring Special Code Acceptance TAFATNEB 0 5,382 02-12-2015, 01:32 PM
  CONCRETE SHEAR WALL DESIGN aslam 2 8,238 08-20-2014, 07:47 AM
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 3,889 06-01-2014, 03:35 PM
  Seismic performance of a 12-storey ductile concrete shear wall system designed accord TAFATNEB 0 4,429 04-21-2014, 10:41 PM
  ASCE Bundle Journal for Nonlinear Stress-Strain Model (Concrete, Reinforced Bar, Stee RyanRS 0 4,798 07-27-2013, 05:13 AM
Last Post: RyanRS
