Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SEISMIC RESPONSE OF UNANCHORED CYLINDRICAL LIQUID-TANK SYSTEMS
05-10-2014, 09:35 AM
Author: Feng Qu | Size: 7.5 MB | Format: PDF | Quality: Unspecified | Publisher: Carleton University Ottawa, Ontario, Canada May 1997 | Year: 1992 | pages: 225
[Image: 58559432032456247186.jpg]
The "uplift mecbanismn, developed in response to large overtuniing moment, is the dominant response behaviour of unanchored liquid-tank systems under seismic load. Associated wi t h the base plate uplift , significant deformation and intensive stresses are developed in the tank structure. intense iiquid motion, both the impulsive and the convective component, is also induced fiom the coupling effect. The uplift mechanism is highly nonlinear. Its significance and mechanism in contributing to the seismic behaviour is not fully understood. In this thesis, the seismic behaviour time history of an unanchored broad liquid- tank system is analyzed with the focus on the uplift mechanism. The 1940 El Centro
and the 1994 Northridge earthquakes are used as the ground excitations. The up- lift phenomenon of the base plate, its effects on the shell wall deformation and the dynamic characteristics of the liquid-tank system are studied. The liquid motion developed in the partially uplifted liquid- tank system and the corresponding hydro- dynamic loads are analyzed. The intensive stress developed in the tank structure and the failure mechanism are discussed. A parametric study is conducted to define the effects of the properties of the liquid-tank system on the uplift rnechanism. The seismic behaviour tirne history of mode1 liquid-tank systems with variant structural stiffness and liquid height to tank radius ratio are studied. By varying these parameters, the uplift behaviour, liquid motion and structural stress of the liquid-tank system are carefully compared 2nd deterrnined.
  • ssobhan, slowet, ting tsai huang, vardan, malc, mgdario
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,808 03-27-2015, 11:44 AM
  Influence of Damping Systems On Building Structures Subject to Seismic Effects TAFATNEB 0 1,593 12-26-2014, 10:06 PM
  STEEL DISSIPATIVE BRACING SYSTEMS FOR SEISMIC RETROFITTING OF EXISTING STRUCT TAFATNEB 0 1,784 10-08-2014, 02:17 PM
  VIBRATIONAL CHARACTERISTICS AND SEISMIC ANALYSIS OF CYLINDRICAL LIQUID STORAGE TANKS TAFATNEB 0 1,632 05-10-2014, 09:48 AM
  analysis of unanchored liquid storage talks under seismic loads TAFATNEB 0 1,619 05-10-2014, 09:27 AM
  A Computational Framework for Sloshing in Liquid Storage Tank: Theory and Application TAFATNEB 0 1,629 05-10-2014, 08:58 AM
  Structural Response and Cost Characterization of Bridge Construction using Seismic Pe TAFATNEB 0 1,464 05-09-2014, 03:10 PM
