Civil Engineering Association eBooks Structural Books Concrete Theory of Beam-Columns, Volume 1: In-Plane Behavior and Design
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
Points:24,374 EP
04-15-2014, 09:07 AM (This post was last modified: 04-15-2014, 02:27 PM by usman.)
Author: by Wai-Fah Chen , Toshio Atsuta | Size: 51 MB | Format: PDF | Quality: Unspecified | Publisher: J. Ross Publishing | Year: 2007 | pages: 536 | ISBN: ISBN-10: 1932159762 | ISBN-13: 978-1932159769
[Image: 61230718917786257291.jpg]
This first volume of a two-volume work presents the basic theoretical principles, methods of analysis in obtaining the solutions of beam-columns, and developments of theories of biaxially loaded beam-columns, and shows how these theories can be used in the solution of practical design problems. After presenting the basic theory the authors proceed to solutions of particular problems. The book discusses both refined and simplified design procedures, along with their limitations. It is left to the engineer to choose among them as he sees fit.
An unabridged J. Ross Publishing republication of the edition published by McGraw-Hill, Inc., New York, 1976, 536pp.
Key Features
-Discusses the complete theory of beam-columns from the most elementary to the most advanced state of development
-Presents various methods of solution that are best suited for different types of beam-column problems
-Provides numerical results in terms of tables, charts, and diagrams which furnish values of critical loads for various beam-column problems
[-] The following 23 users Like bigone's post:23 users Like bigone's post
  • cace-01, nima_b12, rezart, ssobhan, Mohammad6299, PinkPant, apocalipse, Dell_Brett, zrilek, adams, sodapas, cristi, blaze, shaker, ykhackhack, peixoto, mohcivil, amindoxiti, yanburak, vvvv, temp1366, igor1234, K.Lee
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,912 in 854 posts
Given Likes: 4212
Points:59,515 EP
04-19-2014, 03:34 AM (This post was last modified: 04-19-2014, 03:35 AM by Mohammad6299.)
[Image: comments.png]
PDF file is OCRed.
[-] The following 22 users Like Mohammad6299's post:22 users Like Mohammad6299's post
  • aslam, dl4all, subin91, gulilero, bigone, blaze, vardan, malc, pontiac, cace-01, Dell_Brett, PinkPant, zrilek, oanm2000, ykhackhack, milova, ruaumoko, bridgeengineer, sodapas, amindoxiti, mohcivil, Jackass
 bigone
User ID: 4505
Threads: 92
Given Likes: 7145
Points:24,374 EP
01-29-2015, 08:31 AM
Mirror of Post #1
[-] The following 14 users Like bigone's post:14 users Like bigone's post
  • slowet, ykhackhack, bridgeengineer, blaze, Dell_Brett, vvvv, ssobhan, oanm2000, melekeen, agarciam2, jcbv, warlord1, Trishu999, PinkPant
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
Points:21,872 EP
01-29-2015, 05:24 PM
Use official password,
44.00 MB
[-] The following 5 users Like Veggeta's post:5 users Like Veggeta's post
  • oanm2000, PinkPant, bigone, bridgeengineer, Dell_Brett
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2616
Points:35,180 EP
05-31-2016, 11:39 AM (This post was last modified: 05-31-2016, 11:43 AM by amindoxiti. Edit Reason: N/A )
Theory of Beam-Columns, Volume 2: Space Behavior and Design
Author(s)/Editor(s): Wai-Fah Chen, Toshio Atsuta | Size: 84 MB | Format: PDF | Quality: Unspecified | Publisher: J. Ross Publishing | Year: 2008 | pages: 767 | ISBN: 1932159770
[Image: 25531612271529573054.jpg]
Chen and Atsuta have extended their comprehensive work on the analysis of beam-columns into three dimensions in this second volume. They have systematically developed the full theory for steel and concrete elements up to their ultimate limit states. The theoretical refinements to cover the residual stesses, plasticity, local and overall buckling and their interaction are well set out.
-Jonathan Wood in New Civil Engineer
This second volume of a two-volume work discusses systematically the complete theory of space beam-columns. The book presents principles and methods of analysis for beam-columns in space, which should be the basis for structural design, and shows how these theories are applied for the solution of practical design problems. With the importance of the role of beam-columns in modern structures, this set of books will be invaluable to structural engineers, designers, specification writing bodies, and researchers.
An unabridged J. Ross Publishing republication of the edition published by McGraw-Hill, Inc., New York, 1977, 752pp.
Key Features
-Provides differential equations of beam-columns in space that are derived from general forms and are given in their corresponding elastic solutions
-Covers the plastic behavior of cross sections, strain hardening, elastic unloadings, and various numerical solution methods
-Includes design problems of plastic beam-columns in space that are solved applying various numerical methods: approximate deflection method, influence coefficient method, and others
[-] The following 21 users Like amindoxiti's post:21 users Like amindoxiti's post
  • slowet, f_slikken, cace-01, sabooryan, PinkPant, oanm2000, malc, ssobhan, mgdario, gulilero, caifan, zrilek, temp1366, igor1234, bridgeengineer, K.Lee, milova, subin91, Dell_Brett, scorpion07, ruaumoko
