Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 3834: Quality requirements for fusion welding of metallic materials
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
01-13-2012, 05:09 AM (This post was last modified: 02-21-2014, 08:16 PM by usman.)
PD CEN ISO/TR 3834-6:2007 Quality requirements for fusion welding of metallic materials. Guidelines on implementing ISO 3834
Size: 1.4 MB | Format: PDF | Quality: Original preprint | Year: 31 May 2007 | pages: 32 | ISBN: 978 0 580 50779 3
[Image: 47471640132253408054.png]
PD CEN ISO/TR 3834-6:2007 gives guidelines for the implementation of requirements given in the other parts of BS EN ISO 3834, and is intended to help manufacturers and users select the part of BS EN ISO 3834 appropriate to their needs. It is expected that they will already be familiar with BS EN ISO 3834 series as a whole.
Welding is a special process in that the final result may not be able to be verified by testing. The quality of the weld is manufactured into the product, not inspected. This means that welding normally requires continuous control or that specific procedures be followed, or both. BS EN ISO 3834 deals with quality requirements in welding and has been prepared in order to identify those controls and procedures.
BS EN ISO 3834 is not a quality system standard intended to take the place of ISO 9001, but a useful, additional tool for use when ISO 9001 is applied by manufacturers, in which case the meeting of its requirements needs to be recorded in certificates or documentation. However, BS EN ISO 3834 can be used independently of ISO 9001.
BS EN ISO 3834 is intended for the fusion welding of metallic materials, and its application is independent of the products manufactured. However, its principles and many of its detailed requirements are also relevant for other welding and welding-related processes.
Among other international standards covering resistance welding and thermal spraying are BS EN ISO 14554 and BS EN ISO 14922, respectively.
One of the aims of BS EN ISO 3834 is to define requirements in the field of welding so that contracting parties or regulators do not have to do it themselves. A reference to a particular part of BS EN ISO 3834 should be sufficient to demonstrate the capabilities of the manufacturer to control welding activities for the type of work being done. This concept also applies to committees responsible for drafting product standards.
BS EN ISO 3834 does not in itself require external assessment or certification. However, assessments by customers and certification by independent bodies are growing trends in commercial relations and the standard can serve as a basis for these purposes, as well as for the demonstration of performance by those manufacturers implementing it.
Contents include:
Normative references
Abbreviated terms
Using ISO 3834
Product standards
Purchasers and users
Quality management systems in accordance with ISO 9001
Quality management systems other than ISO 9001
Manufacturers
Incorporating ISO 3834 in product standards
Using other documents with ISO 3834
Documentation and quality systems
Selecting the level of quality requirements
Implementation in fabrication
General guidelines for implementation
Organization
Interpretation of particular clauses in ISO 3834
Requirements review and technical review
Sub-contracting
Welding coordination
Equipment
Welding activities
Storage of parent metal
Calibration and validation
Identification and traceability
Assessment and certification
Examples of documents for control of welding
Bibliography
PD CEN ISO/TR 3834-6:2007 replaces PD CR 13576:1999, which has been withdrawn
[-] The following 6 users Like mybest's post:6 users Like mybest's post
  • kowheng, peixoto, NBZ1400, Jackass, vpmohammed, Dell_Brett
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
02-21-2014, 02:21 PM
[-] The following 4 users Like Mohammad6299's post:4 users Like Mohammad6299's post
  • st77bel, Dell_Brett, zrilek, jcbv
 Mohammad6299
User ID: 42302
Threads: 261
Given Likes: 4212
02-21-2014, 03:16 PM (This post was last modified: 02-21-2014, 04:18 PM by usman.)
BS EN ISO 3834-5:2005: Quality requirements for fusion welding of metallic materials — Part 5: Documents with which it is necessary to conform to claim conformity to the quality requirements of ISO 3834-2, ISO 3834-3 or ISO 3834-4
Size: 400 KB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2006 | Pages: 16 | ISBN: 9780580600852
[Image: 20904491275600842134.jpg]
This part of ISO 3834 specifies the documents with which it is necessary to conform to claim conformity to the quality requirements of ISO 3834-2, ISO 3834-3 or ISO 3834-4. It can only be used in conjunction with ISO 3834-2, ISO 3834-3 or ISO 3834-4.
  • jcbv, st77bel, Dell_Brett, zrilek
 Mohammad6299
User ID: 42302
Threads: 261
Given Likes: 4212
02-21-2014, 03:25 PM (This post was last modified: 02-21-2014, 03:49 PM by Mohammad6299.)
BS EN ISO 3834-4:2005: Quality requirements for fusion welding of metallic materials —Part 4: Elementary quality requirements
Size: 400 KB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2006 | Pages: 12 | ISBN: 0580476219
[Image: 53441242228746461545.jpg]
This part of ISO 3834 defines elementary quality requirements for fusion welding of metallic materials both in workshops and at field installation sites.
 Mohammad6299
User ID: 42302
Threads: 261
Given Likes: 4212
02-21-2014, 03:44 PM
BS EN ISO 3834-2:2005: Quality requirements for fusion welding of metallic materials — Part 2: Comprehensive quality requirements
Size: 600 KB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2006 | Pages: 20 | ISBN: 0580476235
[Image: 35685875276393973706.jpg]
This part of ISO 3834 defines comprehensive quality requirements for fusion welding of metallic materials both in workshops and at field installation sites.
 Mohammad6299
User ID: 42302
Threads: 261
Given Likes: 4212
02-21-2014, 03:54 PM
BS EN ISO 3834-3:2005: Quality requirements for fusion welding of metallic materials — Part 3: Standard quality requirements
Size: 600 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2006 | Pages: 18 | ISBN: 0580476227
[Image: 55870222265056944449.jpg]
This part of ISO 3834 defines standard quality requirements for fusion welding of metallic materials both in workshops and at field installation sites.
 Mohammad6299
User ID: 42302
Threads: 261
Given Likes: 4212
02-21-2014, 07:43 PM
BS EN ISO 3834-1:2005: Quality requirements for fusion welding of metallic materials — Part 1: Criteria for the selection of the appropriate level of quality requirements
Size: 700 MB | Format: PDF | Quality: Scanner | Publisher: CEN | Year: 2006 | Pages: 18 | ISBN: 0580476243
[Image: 56525366289659077559.jpg]
This part of ISO 3834 provides a general outline of ISO 3834 and criteria to be taken into account for the selection of the appropriate level of quality requirements for fusion welding of metallic materials, among the three levels specified in ISO 3834-2, ISO 3834-3 and ISO 3834-4. It applies to manufacturing, both in workshops and at field installation sites.
[-] The following 3 users Like Mohammad6299's post:3 users Like Mohammad6299's post
  • Dell_Brett, st77bel, zrilek
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
01-08-2015, 05:35 PM
new link
password:
  • st77bel, Dell_Brett, jcbv, PinkPant, bridgeengineer, Mohammad6299
  ISO 12737:2005 Metallic materials -- Determination of plane-strain fracture toughne ir_71 2 2,600 01-08-2015, 04:13 PM
  ISO 12106:2003 Metallic materials — Fatigue testing ir_71 2 2,801 01-08-2015, 04:11 PM
  ISO 1099:2006 Metallic materials — Fatigue testing - Axial force-controlled method ir_71 2 2,752 01-08-2015, 03:41 PM
