Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 301: Specifications for Structural Concrete
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
11-20-2009, 05:48 AM (This post was last modified: 12-20-2011, 06:41 PM by usman.)
SP15(05): Field Reference Manual: Standard Specifications for Structural Concrete ACI 301-05 with Selected ACI References
[Image: 40701278313299019196.jpg]
An essential reference document, SP-15(05): Field Reference Manual contains ACI 301-05 Specifications for Structural Concrete in its entirety, along with 18 related ACI committee documents, including Chapter 3 through 7 of ACI 318-05 Building Code Requirements for Structural Concrete. Included in SP-15(05) are: ACI 117/117R-90 Standard Specifications for Tolerances for Concrete Construction and Materials and Commentary; ACI 302.1R-04 Guide for Concrete Floor and Slab Construction; ACI 305R-99 Hot Weather Concreting; ACI 306R-88 Cold Weather Concreting; ACI 308R-01 Guide to Curing Concrete; ACI 347-04 Guide to Formwork for Concrete, and 11 other documents. 660 pp.
SP15(05): Field Reference Manual: Standard Specifications for Structural Concrete ACI 301-05 with Selected ACI References - Table of Contents:
* ACI 301-05 Specifications for Structural Concrete
* ACI 116R-00 Cement and Concrete Terminology
* ACI 117/117R-90 Standard Specifications for Tolerances for Concrete Construction and Materials and Commentary
* ACI 212.3R-04 Chemical Admixtures for Concrete
* ACI 213R-03 Guide For Structural Lightweight-Aggregate Concrete
* ACI 214R-02 Evaluation of Strength Test Results of Concrete
* ACI 214.4R-03 Guide for Obtaining Cores and Interpreting Compressive Strength Results
* ACI 224.1R-93 (Reapproved 1998) Causes, Evaluation and Repair of Cracks in Concrete Structures
* ACI 229R-99 (Reapproved 2005) Controlled Low-Strength Materials
* ACI 302.1R-04 Guide for Concrete Floor and Slab Construction
* ACI 303R-04 Guide to Cast-in-Place Architectural Concrete Practice
* ACI 403R-00 Guide for Measuring, Mixing, Transporting, and Placing Concrete
* ACI 305R-99 Hot Weather Concreting
* ACI 306R-88 (Reapproved 2002) Cold Weather Concreting
* ACI 308R-01 Guide to Curing Concrete
* ACI 309R-96 Guide for Consolidation of Concrete
* ACI 318-05 Building Code Requirements for Structural Concrete (Chapters 3-7)
* ACI 347-04 Guide to Formwork for Concrete
* ACI 533.1R-02 Design Responsibility for Architectural Precast-Concrete Projects
[-] The following 27 users Like junaid's post:27 users Like junaid's post
  • abudabeeja, kowheng, vvvv, Dell_Brett, miquan, str2ral, STRAIN, ia_ranco, sangen, banky4354, amira, AALIHU, julioreptil, carinacab, ziadjordan, ibg0203, ngcanhtoan, pedzaquino, bosnawi, Umer.Aleem, arceon, simanta, Mhasan, marcel1983, adrian_p_2002, visu, bigone
 st77bel
Romania
User ID: 12964
Threads: 16
Likes: 432 in 86 posts
Given Likes: 696
10-19-2013, 04:58 PM
All links are dead. Please re-upload.
[-] The following 3 users Like st77bel's post:3 users Like st77bel's post
  • mohamz, aymanalrasheed, Umer.Aleem
12-07-2013, 06:14 PM (This post was last modified: 08-20-2014, 02:46 PM by Dell_Brett.)
ACI 301-10 Specifications for Structural Concrete
Author: ACI Committee 301 | Size: 35.71 MB | Format: PDF | Quality: Image PDF | Publisher: ACI | Year: 2010 | pages: 77 | ISBN: 9780870314032
[Image: 60625368669675816007.jpg]
This document covers general construction requirements for cast-in-place structural concrete and slabs-on-ground. The first five sections cover materials and proportioning of concrete; reinforcement and prestressing steel; production, placing, finishing, and curing of concrete; formwork performance criteria and construction; treatment of joints; embedded items, repair of surface defects; and finishing of formed and unformed surfaces. Provisions governing testing, evaluation, and acceptance of concrete as well as acceptance of the structures are included. The remaining sections are devoted to architectural concrete, lightweight concrete, mass concrete, posttensioned concrete, shrinkage-compensating concrete, industrial floor slabs, tilt-up construction, precast structural concrete, and precast architectural concrete.
Keywords: architectural; cold weather; compressive strength; durability; concrete slab; consolidation; curing; finish; formwork; grouting; hot weather; industrial floors; inspection; joints; lightweight concrete; mass concrete; mixture proportions; placing; precast; post-tensioned; prestressing steel; repair; reshoring; shoring; shrinkage-compensating; slabs-on-ground; steel reinforcement; testing; tilt-up; tolerance; welded wire.
  • ykhackhack, shaker, fred2010, pezhmankhan, Dell_Brett, blaze, bigone, subin91, eliseo.as, lisine, malc, zrilek, harsono, Mohammad6299, vvvv
12-07-2013, 06:28 PM
ACI 301M-10 Specifications for Structural Concrete (metric)
Author: ACI Committee 301 | Size: 65.93 MB | Format: PDF | Quality: Image PDF | Publisher: ACI | Year: 2010 | pages: 77 | ISBN: 9780870314032
[Image: 75413002195023735862.jpg]
[-] The following 22 users Like ir_71's post:22 users Like ir_71's post
  • vardan, Hengki, rezart, ssobhan, maad59, oanm2000, techno, simanta, herea, fred2010, pezhmankhan, Dell_Brett, pedzaquino, rendel_©, subin91, vvvv, bigone, eliseo.as, lisine, shaker, knrsa, sacem
Likes: 12,073 in 1,233 posts
12-08-2013, 04:57 AM
Page 22 of the document is not unprotected.
Please reupload this page.
[-] The following 2 users Like pezhmankhan's post:2 users Like pezhmankhan's post
  • fred2010, bigone
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
12-09-2013, 11:08 AM (This post was last modified: 12-09-2013, 12:35 PM by lisine.)
Page 22 in post #1 is blocked by Vitrium protected image, which can be deleted in Acrobat Professional.
Or download this document with unprotected page 22.
[Image: 24196504327134391417.jpg]
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  • Dell_Brett, dinu69in, pezhmankhan, fred2010, malc, zrilek, harsono, blaze, zego2000, er.shyams, spat
12-09-2013, 04:44 PM (This post was last modified: 12-09-2013, 04:46 PM by pezhmankhan.)
OCRed & Searchable Text:
[-] The following 5 users Like pezhmankhan's post:5 users Like pezhmankhan's post
  • fred2010, Dell_Brett, simanta, gulilero, sacem
 ykhackhack
United States
User ID: 36960
Threads: 81
Likes: 3,670 in 707 posts
Given Likes: 8693
08-19-2014, 10:28 PM
@MEKKAWI
[-] The following 8 users Like ykhackhack's post:8 users Like ykhackhack's post
  • MEKKAWI, inge911, Mohammad6299, bigone, julioreptil, bridgeengineer, sacem, spat
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
08-20-2014, 04:38 AM
djvu 1.32 MB
password:
[-] The following 8 users Like andersen3's post:8 users Like andersen3's post
  • vardan, PinkPant, Mohammad6299, vvvv, Dell_Brett, ykhackhack, bigone, bridgeengineer
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
08-20-2014, 01:19 PM
ACI 301M-10 - Specifications for Structural Concrete (Metric)
Author: ACI Committee 301 | Size: 0.5 MB | Format: PDF | Quality: Original preprint | Publisher: American Concrete Institute (ACI) | Year: 2011 | Pages: 77 | ISBN: 9780870314117, 0870314114
This is a Reference Specification that the Architect/Engineer can apply to any construction project involving structural concrete by citing it in the Project Specifications. Checklists are provided to assist the Architect/Engineer in supplementing the provisions of this Reference Specification as needed by designating or specifying individual project requirements. The first five sections of this document cover general construction requirements for cast-in-place structural concrete and slabs-on-ground. These sections cover materials and proportioning of concrete; reinforcement and prestressing steel; production, placing, finishing, and curing of concrete; formwork performance criteria and construction; treatment of joints; embedded items; repair of surface defects; and finishing of formed and unformed surfaces. Provisions governing testing, evaluation, and acceptance of concrete as well as acceptance of the structures are included. The remaining sections are devoted to architectural concrete, lightweight concrete, mass concrete, post-tensioned concrete, shrinkagecompensating concrete, industrial floor slabs, tilt-up construction, precast structural concrete, and precast architectural concrete.
[Image: comments.png]
ERRATA as of March 15, 2012 is included.
[-] The following 20 users Like Mohammad6299's post:20 users Like Mohammad6299's post
  • andersen3, oanm2000, techno, Dell_Brett, milova, eliseo.as, zrilek, malc, ykhackhack, melekeen, ruaumoko, ir_71, bigone, Jackass, simanta, bridgeengineer, zego2000, ISTRAKTURA, spat, rami1976
Pages (2): 1 2 Next »
  ACI 350.5: Specifications for Environmental Concrete Structures Mohammad6299 1 2,291 05-07-2023, 10:51 AM
