Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 522: Report on Pervious Concrete
11-23-2013, 02:05 PM (This post was last modified: 05-03-2023, 08:16 AM by Administrator.)
ACI 522R-10 Report on Pervious Concrete (Reapproved 2011)
Author: ACI Committee 522 | Size: 20.66 MB | Format: PDF | Quality: Image PDF | Publisher: ACI | Year: 2010 | pages: 38 | ISBN: 9780870313646
[Image: 84211314099117779787.jpg]
This report provides technical information on pervious concrete’s application, design methods, materials, properties, mixture proportioning, construction methods, testing, and inspection.
The term “pervious concrete” typically describes a near-zero-slump, open-graded material consisting of portland cement, coarse aggregate, little or no fine aggregate, admixtures, and water. The combination of these ingredients will produce a hardened material with connected pores, ranging in size from 0.08 to 0.32 in. (2 to 8 mm), that allow water to pass through easily. The void content can range from 15 to 35%, with typical compressive strengths of 400 to 4000 psi (2.8 to 28 MPa). The drainage rate of pervious concrete pavement will vary with aggregate size and density of the mixture, but will generally fall into the range of 2 to 18 gal./ min/ft2 (81 to 730 L/min/m2). Pervious concrete is widely recognized as a sustainable building material, as it reduces stormwater runoff, improves stormwater quality, may recharge groundwater supplies, and can reduce the impact of the urban heat island effect.
Keywords: construction; design; drainage; green building; LEED® credit; permeability; pervious concrete pavement; stormwater; sustainability; testing.
  • blaze, vardan, fred2010, malc, bigone, ykhackhack, Dell_Brett, ssobhan, andersen3, lisine, st77bel, Rapaig, zrilek, jonamcivil, harsono, peymanlord
05-03-2023, 08:15 AM
ACI PRC-522-10 Report on Pervious Concrete (Reapproved 2011)
Author(s)/Editor(s): ACI Committee 522| Format: PDF| Quality: Original preprint| Year: 2010| pages: 40 | ISBN: 9780870313646
[Image: 95707115827387534362.png]
The term “pervious concrete” typically describes a near-zero-slump, open-graded material consisting of portland cement, coarse aggregate, little or no fine aggregate, admixtures, and water. The combination of these ingredients will produce a hardened material with connected pores, ranging in size from 0.08 to 0.32 in. (2 to 8 mm), that allow water to pass through easily. The void content can range from 15 to 35%, with typical compressive strengths of 400 to 4000 psi (2.8 to 28 Mpa). The drainage rate of pervious concrete pavement will vary with aggregate size and density of the mixture, but will generally fall into the range of 2 to 18 gal./ min/ft2 (81 to 730 L/min/m2). Pervious concrete is widely recognized as a sustainable building material, as it reduces stormwater runoff, improves stormwater quality, may recharge groundwater supplies, and can reduce the impact of the urban heat island effect.
  • Dell_Brett, babakfeyzi, PinkPant, milova, subin91
  [CivilEA Exclusive] ACI 228.1: Report on Methods for Estimating In-Place Concrete Strengt poolmand 0 1,292 12-14-2024, 01:23 PM
  [CivilEA Exclusive] ACI 334.3: Construction of Concrete Shells Using Inflatable Forms - Report poolmand 0 1,222 12-14-2024, 01:04 PM
  ACI 370: Report for the Design of Concrete Structures for Blast Effects er.shyams 1 2,462 05-09-2023, 09:25 AM
  ACI 445.1: Report on Torsion in Structural Concrete Mohammad6299 3 2,974 05-08-2023, 07:15 AM
  ACI 207.5: Report on Roller-Compacted Mass Concrete Mohammad6299 1 2,084 05-07-2023, 10:06 AM
  ACI 325.10: Report on Roller-Compacted Concrete Pavements Mohammad6299 1 2,114 05-07-2023, 07:09 AM
  ACI 363: Report on High-Strength Concrete Mohammad6299 1 2,361 05-07-2023, 05:28 AM
