Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis A STUDY ON SEISMIC BEHAVIOUR OF MASONRY TOWERS
11-18-2013, 08:28 PM (This post was last modified: 11-18-2013, 09:28 PM by usman.)
Author: Prof. Davide Bigoni | Size: 17.1 MB | Format: PDF | Quality: Unspecified | Publisher: UNIVERSITY OF TRENTO Modeling, Preservation and Control of Materials and Structures Ph. D. | Year: 08/04/2011 | pages: 172
[Image: 04109972322617294455.png]
This study is dedicated to simplified vulnerability assessment of
masonry towers, in particular to the definition of collapse mechanism geometry.
After a preliminary analysis on damages and collapse mechanisms
caused to towers by the earthquakes and a review of analysis
methods in literature, a model to determine the plane of fracture that defines the kinematic blocks of an overturning mechanism was proposed, based on simple equilibrium conditions.
According to the Italian codes, in fact, tower structures are classified as one of the churches macroelements, characterized by peculiar collapse mechanisms; respect to other macroelements, for towers a slight variation in mechanism geometry implies relevant variation in collapse multiplier values; this is mainly due to the importance of mass and height in these structures. Hence a correct definition of kinematism geometry results very important.
The proposed method was applied also including a limit on masonry compressive strength, despite traditional limit analysis method that usually assumes as infinite masonry compressive strength.
For the use in common practice, the curve of fracture was evaluated through parametric analyses for different geometrical configurations, to which many existing towers can be assimilated. Finally, besides a comparison with real collapse mechanisms surveyed on towers after earthquakes, the proposed method was applied also in the vulnerability assessment of a medieval masonry tower, the Ghirlandina in Modena.
  • rezart, malc, vardan, blaze, subin91, draluka, joker™
11-20-2013, 01:54 PM
Author: Federica Romaro | Size: 17.7 MB | Format: PDF | Quality: Unspecified | pages: 172
[-] The following 1 user Likes TAFATNEB's post:1 user Likes TAFATNEB's post
  • slowet
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,777 10-08-2014, 02:00 PM
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,742 09-02-2014, 08:10 AM
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 1,721 08-31-2014, 07:45 AM
  Cyclic Properties of Sand: Dynamic Behaviour for Seismic Applications TAFATNEB 0 1,636 08-12-2014, 01:52 PM
  A Study of the Progressive Degradation of Masonry Shear Walls Subjected to Harmonic L TAFATNEB 0 1,595 06-04-2014, 12:00 AM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,664 04-19-2014, 08:58 AM
  ANALYSIS OF RADIO COMMUNICATION TOWERS SUBJECTED TO WIND, ICE AND SEISMIC LOADINGS asim99 4 3,015 04-17-2014, 10:07 AM
