Civil Engineering Association eBooks Structural Books Concrete Compressive Force-Path Method: Unified Ultimate Limit-State Design of Concrete Struct
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
10-07-2013, 12:32 PM
Compressive Force-Path Method: Unified Ultimate Limit-State Design of Concrete Structures
Author: Michael D Kotsovos | Size: 9.4 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2013 | pages: 150 | ISBN: 3319004875
[Image: 66596032389945476855.jpg]
This book presents a method which simplifies and unifies the design of reinforced concrete (RC) structures and is applicable to any structural element under both normal and seismic loading conditions.
The proposed method has a sound theoretical basis and is expressed in a unified form applicable to all structural members, as well as their connections. It is applied in practice through the use of simple failure criteria derived from first principles without the need for calibration through the use of experimental data. The method is capable of predicting not only load-carrying capacity but also the locations and modes of failure, as well as safeguarding the structural performance code requirements.
In this book, the concepts underlying the method are first presented for the case of simply supported RC beams. The application of the method is progressively extended so as to cover all common structural elements. For each structural element considered, evidence of the validity of the proposed method is presented together with design examples and comparisons with current code specifications. The method has been found to produce design solutions which satisfy the seismic performance requirements of current codes in all cases investigated to date, including structural members such as beams, columns, and walls, beam-to-beam or column-to-column connections, and beam-to-column joints.
This post has been made by CivilEA Post-Generator v2.2.0[url=http://postgen.civilea.com/index.html][/url]
Thanks to Original Uploader
[-] The following 17 users Like cace-01's post:17 users Like cace-01's post
  • milova, blaze, ssobhan, NAUTILUS87, oanm2000, Dell_Brett, malc, gulilero, miquan, rusty, AlmostThere, sodapas, warlord1, cristi, zrilek, K.Lee, kowheng
 fred2010
User ID: 56323
Threads: 18
Likes: 545 in 107 posts
Given Likes: 343
10-07-2013, 04:25 PM
[-] The following 6 users Like fred2010's post:6 users Like fred2010's post
  • oanm2000, Dell_Brett, subin91, seriousboy, mgdario, jcbv
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
10-18-2013, 02:13 AM
concrete solution advocate
[-] The following 9 users Like concreteok's post:9 users Like concreteok's post
  • dinu69in, avscorreia, malc, lisine, warlord1, majkyy, Dell_Brett, chenamoy, ruaumoko
 tomtumx
Semi Senior Member
User ID: 2851
Threads: 23
Likes: 725 in 124 posts
Given Likes: 770
07-17-2017, 04:31 AM
[-] The following 14 users Like tomtumx's post:14 users Like tomtumx's post
  • amindoxiti, K.Lee, jcbv, vvvv, Nita1391, febo927, promo8, PinkPant, caifan, melekeen, Dell_Brett, Trishu999, sodapas, kowheng
  [REQUEST] Title: Serviceability Limit State of Concrete Structures viet2010 1 1,914 12-07-2021, 02:13 PM
Last Post: alikhs2002
  Structural Concrete: Strut-and-Tie Models for Unified Design cace-01 1 2,405 02-21-2020, 02:51 PM
  Fastenings to Concrete and Masonry Structures: State of the Art Report by Comite Euro febo927 1 2,041 05-01-2019, 03:28 AM
  Unified Theory of Concrete Structures By Thomas Hsu et al ziggywas1 13 7,277 07-20-2018, 03:54 AM
Last Post: axcel
  Limit Analysis and Concrete Plasticity, 3rd Ed hich 9 7,218 07-19-2018, 01:09 PM
  The Ultimate Load Design of Continuous Concrete Beams febo927 0 1,651 07-17-2018, 01:23 PM
Last Post: febo927
  CS TR59 - Influence of tension stiffening on deflection of reinforced concrete struct ir_71 0 1,527 03-08-2017, 04:40 PM
