07-27-2013, 05:21 AM
Hi all, I'm looking for concrete blocks calculation for pipeline. Does anyone have spreadsheet or references as my guidance...thanks civilea...
Concrete Blocks Current time: 04-11-2021, 07:15 PM |
[Request] Concrete Blocks
07-27-2013, 07:18 AM
*************************************** The link above has a simple approach with indicative values for thrust block design. I would use that as a guideline for the overall size of the block. Alternatively, you could design using passive earth pressure if the situation called for a more detailed analysis and you had good geotech information available. Shear key / shear transfer design would be as per column base plate design. Plenty of good references on this forum for that also. Regards elbarto
