Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 408:2010 Timber structures - Structural timber and glued laminated timber - Det
06-15-2013, 05:18 PM
BS EN 408:2010 Timber structures - Structural timber and glued laminated timber - Determination of some physical and mechanical properties
Author: Technical Committee CEN/TC 124 "Timber structures" | Size: 7.15 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2010 | pages: 36
[Image: 07488786629381240516.jpg]
This European Standard specifies test methods for determining the following properties of structural timber and glued laminated timber: modulus of elasticity in bending; shear modulus; bending strength; modulus of elasticity in tension parallel to the grain; tension strength parallel to the grain; modulus of elasticity in compression parallel to the grain; compression strength parallel to the grain; modulus of elasticity in tension perpendicular to the grain; tension strength perpendicular to the grain; modulus of elasticity in compression perpendicular to the grain; compression strength perpendicular to the grain and shear strength .
In addition, the determination of dimensions, moisture content, and density of test pieces are specified.
The methods apply to rectangular and circular shapes (of substantially constant cross section) of solid unjointed timber or finger-jointed timber and glued laminated timber unless stated otherwise.
  • Dell_Brett, jcbv, st77bel, Jackass, ykhackhack, zrilek, warbeast, andersen3, Trishu999, asim99, peixoto, kowheng, avge
 albani
Semi Senior Member
User ID: 23104
Threads: 11
Likes: 683 in 78 posts
Given Likes: 1025
08-30-2023, 06:30 PM
All link are dead!
Can someone renew, or maybe share EN 408:2010+A1:2012
thanks in advance
If you can't run, keep walking.
  EN 26891 - Timber structures. Joints made with mechanical fasteners ir_71 1 1,693 07-01-2021, 08:41 AM
Last Post: zrilek
  BS 644:2009 Timber windows. Fully finished factory-assembled windows of various types mybest 2 2,257 02-25-2013, 07:12 AM
Last Post: arshiakh
  BS 5589:1989 Code of practice for preservation of timber ir_71 1 2,062 02-14-2013, 01:00 PM
  BS EN 14358:2006 Timber structures. Calculation of characteristic 5-percentile values mybest 0 1,785 11-28-2011, 06:16 PM
Last Post: mybest
  BS EN 383:2007 Timber structures. Test methods. Determination of embedment strength a mybest 0 1,958 11-28-2011, 06:08 PM
Last Post: mybest
  BS EN 1995-1-1:2004+A1:2008 Eurocode 5. Design of timber structures. General. Common mybest 0 2,054 11-28-2011, 05:49 PM
Last Post: mybest
