Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 13628-5:2009 Petroleum and natural gas industries -- Design and operation of subs
01-17-2013, 05:41 PM
ISO 13628-5:2009 Petroleum and natural gas industries -- Design and operation of subsea production systems -- Part 5: Subsea umbilicals
Author: ISO TC 67/SC 4 | Size: 1.88 MB | Format: PDF | Quality: Original preprint | Publisher: ISO | Year: 2009 | pages: 168
[Image: 64332700386568734045.jpg]
ISO 13628-5:2009 specifies requirements and gives recommendations for the design, material selection, manufacture, design verification, testing, installation and operation of umbilicals and associated ancillary equipment for the petroleum and natural gas industries. Ancillary equipment does not include top side hardware. Topside hardware refers to any hardware that is not permanently attached to the umbilical, above the topside hang-off termination.
ISO 13628-5:2009 applies to umbilicals containing components, such as electrical cables, optical fibres, thermoplastic hoses and metallic tubes, either alone or in combination; and to umbilicals for static or dynamic service, with surface-surface, surface-subsea and subsea-subsea routings .
ISO 13628-5:2009 does not apply to the associated component connectors, unless they affect the performance of the umbilical or that of its ancillary equipment.
ISO 13628-5:2009 applies only to tubes with the following dimensions: wall thickness, t  6 mm, internal diameter, ID  50,8 mm (2 in). Tubular products greater than these dimensions can be regarded as pipe/linepipe and it is expected that they be designed and manufactured according to a recognised pipeline/linepipe standard.
ISO 13628-5:2009 does not apply to a tube or hose rated lower than 7 MPa (1 015 psi), or to electric cable voltage ratings above standard rated voltages = 3,6/6(7,2) kV rms, where U0, U and Um are as defined in IEC 60502-1 and IEC 60502-2.
  • malc, kowheng, andersen3, peixoto, Dell_Brett, asim99
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
01-08-2015, 04:39 PM
new links
password:
  • zrilek, Dell_Brett, PinkPant, bridgeengineer, scorpion07
  ISO 19901-1,2,4,6 Petroleum and Natural Gas Industries-Specific Req for Offshore Strs ir_71 10 8,915 09-10-2018, 11:35 PM
Last Post: malc
  ISO 19900-2002 Petroleum and natural gas industries -- General requirements for offsh andersen3 1 2,107 01-08-2015, 04:45 PM
  ISO FDIS 19906:2009 Petroleum and natural gas industries — Arctic offshore structures ir_71 2 2,784 01-08-2015, 04:30 PM
  ANSI/API RP-17A-2006(ISO 13628-1) Design and Operation of Subsea Production Systems—G ir_71 2 2,745 01-08-2015, 04:22 PM
