Civil Engineering Association eBooks GIS, Surveying & Geomatics Topographical surveying: including: Topographical surveying
12-08-2012, 08:42 AM
Author: George J. Specht, Arthur Sherburne Hardy, John Bach McMaster, Henry Francis Walling | Size: 7 MB | Format: PDF | Quality: Scanner | Publisher: D. Van Nostrand | Year: 1898 | pages: 210
[Image: 39246154633316639638.jpg]
The object of Topography is to determine the relative positions of points of the earth's surface, that can be referred without error to a tangent plane, and therefore independent of the sphericity of the globe. The operations of a topographical survey, consequently, are two namely, to first project a system of points upon such a tangent plane ; and, secondly, to find the distances of the same above or below the plane; or, in other words, to measure the lengths of the projecting normals. The first process is ordinary surveying; the second, levehng.The results of a topographical survey are laid down in a so-called topograpliical map, which is a representation or complete image of the ground on a reduced scale.
Topographical maps are of the greatest convenience in locating railroads or other roads, in planning irrigation works, draining Avorks, in mining enterprises, in military operations, &c., &c. In a topographical map the configuration of the ground is reduced to an image, which represents to the eye a large area at one glance,which in nature could not be view edbut by many separate inspections ; therefore, the judgment about the relation of the different parts of the work will be a clearer and more intelligent one. This refers especially to mining work, where very frequently the problem occurs, to strike a vein with a tunnel in a certain level. In this problem a correct topographical map will often save the mining company several hundred feet of tunnel work, or, in other words, thousands of dollars.
[-] The following 5 users Like shadabg's post:5 users Like shadabg's post
  • blaze, kowheng, Dell_Brett, malc, eliseo.as
  Surveying with Construction Applications junaid 8 8,289 07-10-2018, 11:23 AM
Last Post: cace-01
  Surveying instruments and technology cace-01 0 2,990 08-19-2017, 04:54 PM
Last Post: cace-01
  Plane and Geodetic Surveying kvtasp 2 4,081 02-29-2016, 06:36 AM
  GPS Satellite Surveying i_kabir 1 3,316 08-22-2015, 11:43 PM
Last Post: emmi
  Surveying Engineering and Instruments asim99 0 1,998 06-02-2013, 02:09 PM
Last Post: asim99
  Adjustment Computations: Statistics and Least Squares in Surveying and GIS oanm2000 2 3,066 05-14-2013, 07:27 AM
  Engineering Surveying - by W. Schofield, Mark Breach abudabeeja 11 8,370 03-28-2013, 05:14 AM
Last Post: pezhmankhan
