Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Damping Models for Structural Vibration
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
12-03-2012, 01:51 PM
Author: Sondipon Adhikari | Size: 3.9 MB | Format: PDF | Quality: Original preprint | Publisher: Cambridge University Engineering Department | Year: 2000 | pages: 228
[Image: 34019635734408162026.jpg]
Abstract
This dissertation reports a systematic study on analysis and identification of multiple parameter damped
mechanical systems. The attention is focused on viscously and non-viscously damped multiple degree-offreedom
linear vibrating systems. The non-viscous damping model is such that the damping forces depend
on the past history of motion via convolution integrals over some kernel functions. The familiar viscous
damping model is a special case of this general linear damping model when the kernel functions have no
memory.
The concept of proportional damping is critically examined and a generalized form of proportional
damping is proposed. It is shown that the proportional damping can exist even when the damping mechanism
is non-viscous.
Classical modal analysis is extended to deal with general non-viscously damped multiple degree-offreedom
linear dynamic systems. The new method is similar to the existing method with some modifications
due to non-viscous effect of the damping mechanism. The concept of (complex) elastic modes and nonviscous
modes have been introduced and numerical methods are suggested to obtain them. It is further
shown that the system response can be obtained exactly in terms of these modes. Mode orthogonality
relationships, known for undamped or viscously damped systems, have been generalized to non-viscously
damped systems. Several useful results which relate the modes with the system matrices are developed.
These theoretical developments on non-viscously damped systems, in line with classical modal analysis,
give impetus towards understanding damping mechanisms in general mechanical systems. Based on a
first-order perturbation method, an approach is suggested to the identify non-proportional viscous damping
matrix from the measured complex modes and frequencies. This approach is then further extended to identify
non-viscous damping models. Both the approaches are simple, direct, and can be used with incomplete
modal data.
It is observed that these methods yield non-physical results by breaking the symmetry of the fitted
damping matrix when the damping mechanism of the original system is significantly different from what is
fitted. To solve this problem, approaches are suggested to preserve the symmetry of the identified viscous
and non-viscous damping matrix.
The damping identification methods are applied experimentally to a beam in bending vibration with
localized constrained layer damping. Since the identification method requires complex modal data, a general
method for identification of complex modes and complex frequencies from a set of measured transfer
functions have been developed. It is shown that the proposed methods can give useful information about
the true damping mechanism of the beam considered for the experiment. Further, it is demonstrated that
the damping identification methods are likely to perform quite well even for the case when noisy data is
obtained.
The work conducted here clarifies some fundamental issues regarding damping in linear dynamic systems
and develops efficient methods for analysis and identification of generally damped linear systems.
[-] The following 13 users Like david-smith's post:13 users Like david-smith's post
  • mahyarov, oanm2000, blaze, jcbv, ting tsai huang, eliseo.as, kowheng, Dell_Brett, gulilero, Grunf, malc, Rami11, cace-01
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
06-24-2016, 09:13 PM
GO TO LINK BELOW FOR THE BOOK WHICH SEEMS TO HAVE ALMOST THE SAME CONTENT.
[-] The following 1 user Likes gulilero's post:1 user Likes gulilero's post
  • zrilek
  TESTING OF VIBRATION DAMPING BINDING SYSTEMS USED ON ALPINE SKI EQUIPMENT TAFATNEB 0 1,618 08-08-2014, 03:54 PM
