Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis The Design of Steel Structure Under the Influence of Blast Loading
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
12-01-2012, 02:18 AM (This post was last modified: 12-08-2013, 12:28 PM by mybest.)
Author: MUhammad Rahal | Size: 6.2 MB | Format: PDF | Quality: Scanner | Publisher: MUhammad Rahal | Year: 2004 | pages: 191
[Image: 68314213020653606756.jpg]
Blast resistant design in the civil sector is a balancing act of risk assessment versus cost of protection. Modem steel buildings designed under the provisions of current codes and
practices, particularly those in urban environments, are incapable of maintaining structural integrity under the influence of random acts of terrorism. Protective measures should focus on minimizing the level of avoidable deaths during a blast, by ensuring that blast loadings do not contribute to structural failure that is remote from the applied load. In order to achieve a complete level of redundancy, it is necessary to relate local structural behavior to global structural behavior.
A typical 11-story office building has been designed for gravity and wind loads. The structure is subjected to three cases of blast loadings on vulnerable regions of the building complex. Elements are modeled using a single degree of freedom dynamic analysis, whereby they are subjected to failure criteria. Upgrades and reinforcement proposals reflect minimum provisions for the prevention of progressive collapse. It is determined that an additional 10.5% of steel for beams, 13% for columns, 22% for connections, and 8.2% for miscellaneous metal are required for upgrade of the steel frame.
ii
[-] The following 10 users Like asim99's post:10 users Like asim99's post
  • david-smith, kowheng, Jackass, lisine, malc, slowet, Dell_Brett, ruaumoko, devilmaycry, K.Lee
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,708 in 1,305 posts
Given Likes: 4621
02-22-2017, 02:40 PM
[-] The following 14 users Like lisine's post:14 users Like lisine's post
  • usman, oanm2000, zrilek, temp1366, lasalleguy, K.Lee, hodzicemir, Andrew seah, Aviator, chenamoy, subin91, dizz, Dell_Brett, mgdario
  HANDBOOK FOR BLAST-RESISTANT DESIGN OF BUILDINGS TAFATNEB 1 3,553 09-13-2018, 01:22 PM
Last Post: febo927
  Blast Design and Analysis TAFATNEB 0 1,582 08-31-2013, 04:21 PM
  Blast Resistant Steel Stud Wall Design - Phd asim99 0 1,686 12-01-2012, 01:45 AM
Last Post: asim99
  WIND LOADING EFFECTS AND EQUIVALENT STATIC WIND LOADING ON LOW-RISE BUILDINGS - Phd asim99 0 1,710 11-27-2012, 03:55 PM
Last Post: asim99
