Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Isolator Installation Sequence and Operational Sketches for buildings
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
11-22-2012, 09:06 PM (This post was last modified: 11-22-2012, 09:07 PM by david-smith.)
Author: Robinson Seismic Ltd | Size: 1.16 MB | Format: PDF | Quality: Scanner | Publisher: Robinson Seismic Ltd | Year: 2001 | pages: 11 | ISBN: N/A
[Image: 97914089411845126007.jpg]
ISOLATOR INSTALLATION SEQUENCES
WITHOUT RETROFIT
a) Form and reinforce column.
b) Position Template Type 1 and fix securely (Sketch 7).
c) Pour concrete to 25mm below underside of plate.
d) Remove Template Type 1.
e) Position bearings on 25mm steel shims (Sketch 8).
f) Grout base of bearing using Conbextra flowable grout with a “flow-through”
technique. Allow to cure (Sketch 9).
g) Cast beams on top of bearings (Sketch 10).
h) Tighten nuts to top and bottom plates.
WITH RETROFIT
a) Form and reinforce column (or base structure).
b) Position template and fix securely (Sketch 11).
d) Cast upper beams on top of template (Sketch 12).
e) Leave falsework for beams and slab in place.
f) Remove template (Sketch 13).
g) Apply paintable type epoxy to topside of upper bearing plate. Bolt bearing to
underside of upper beams. Securely tighten bolts (sketch 14).
h) Grout base using Conbextra flowable grout with “flow through” technique.
Allow to cure (Sketch 15).
i) Tighten nuts to lower plate.
j) Remove propping and false-work.
[Image: comments.png]
File is OCR.
[-] The following 14 users Like david-smith's post:14 users Like david-smith's post
  • pedzaquino, Dell_Brett, ykhackhack, oanm2000, eliseo.as, gulilero, kowheng, blaze, amritarao, Sumatra, malc, vardan, ErnestoIII, zrilek
  Bridgestone - Seismic Isolator for Buildings david-smith 2 2,129 09-14-2014, 09:40 AM
Last Post: RyanRS
