Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Effect of Voids in Grouted, Post-Tensioned Concrete Bridge Construction: Volume 2 – I
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-13-2012, 08:58 AM
Effect of Voids in Grouted, Post-Tensioned Concrete Bridge Construction: Volume 2 – Inspection, Repair, Materials, and Risks
Author: Trejo, David | Size: 34.11 MB | Format: PDF | Quality: Original preprint | Publisher: Texas Transportation Institute | Year: 2009 | pages: 342
[Image: 72989412327111509230.png]
Post-tensioned (PT) bridges are major structures that carry significant traffic. These bridges are designed and constructed because they are economical for spanning long distances. In Texas, there are several signature PT bridges. In the late 1990s and early 2000s, several state highway agencies identified challenges with the PT structures: mainly corrosion of the PT strands. The Texas Department of Transportation (TxDOT) performed some comprehensive inspections of their PT bridges. A consultant’s report recommended that all ducts be re-grouted. However, the environment in Texas is very different than the environments in which the corrosion of the PT strands were observed. The objective of this research was to evaluate the corrosion activity of strands for PT structures and to correlate this corrosion activity with general environmental and void conditions. To achieve this objective, time-variant probabilistic models were developed to predict the tension capacity of PT strands subjected to different environmental and void conditions. Using these probabilistic models, time-variant structural reliability models were developed. The probability of failure of a simplified PT structure subjected to HS20 and HL93 loading conditions was assessed. Both flexural failure and serviceability were assessed. Results indicate that the presence of water and chlorides can lead to significant corrosion rates and failure is dependent on this corrosion activity and the number of strands exposed to these conditions. These results are presented in Volume 1 of this report. To assist TxDOT with developing a plan to mitigate this corrosion, studies were performed to assess repair grout materials, inspection methods, and repair methods. In addition, a general methodology is presented on optimizing repairs. These topics are presented in Volume 2 of this report. An Inspection and Repair Manual was also developed from this research and is presented in a separate report. Results indicate that TxDOT should prevent water and chlorides from infiltrating the tendons — this can be achieved in part by repairing drain lines, ducts, and protecting anchor heads as these conditions can lead to early failure of PT bridges. Recommendations on inspections, repairs, and materials are provided, however, further research on the potential formation of galvanic coupling of strands embedded in both existing and new repair grouts need to be assessed.
  • kowheng, blaze, toa011, Jackass, st77bel, mgdario
  Series: New Directions for Florida Post-Tensioned Bridge gulilero 1 1,712 03-18-2016, 06:33 PM
Last Post: inge911
  Effect of Voids in Grouted, Post-Tensioned Concrete Bridge Construction: Volume 1 – E mahyarov 0 1,449 11-13-2012, 08:55 AM
Last Post: mahyarov
  Evaluation of Long-Term Prestress Losses in Post-Tensioned Box-Girder Bridges mahyarov 0 1,586 10-30-2012, 08:18 AM
Last Post: mahyarov
  Effect of Truck Weight on Bridge Network Costs mahyarov 0 1,255 10-24-2012, 09:46 AM
Last Post: mahyarov
  Design of Precast Concrete Piers for Rapid Bridge Construction in Seismic Regions ir_71 1 2,502 07-19-2012, 03:27 AM
Last Post: vutuyen
  BRIDGE CONSTRUCTION mowafi3m 0 2,086 06-06-2011, 08:38 AM
Last Post: mowafi3m
  CS TR47: Durable Bonded Post-tensioned Concrete Bridges chenamoy 1 2,527 11-21-2010, 06:05 AM
