Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 302.2: Guide for Concrete Slabs that Receive Moisture-Sensitive Flooring Mat.
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
11-12-2012, 11:37 PM (This post was last modified: 05-02-2023, 09:10 AM by Administrator.)
ACI 302.2R-06: Guide for Concrete Slabs that Receive Moisture-Sensitive Flooring Materials
Author: ACI Committee 302 | Size: 3.9 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2006 | pages: 42
Reported by ACI Committee 302
This guide contains materials, design, and construction recommendations
for concrete slabs-on-ground and suspended slabs that are to receive moisture-sensitive
flooring materials. These flooring materials include sheet
rubber, epoxy coatings, vinyl composition tile, sheet vinyl, carpet, athletic
flooring, laminates, and hardwood. Chapters 1 through 8 provide an
understanding of concrete moisture behavior and drying, and show how
recommended construction practices can contribute to successful performance
of floor covering materials. This background provides a basis for
the recommendations in Chapter 9 to improve performance of floor
covering materials in contact with concrete moisture and alkalinity.
Because this guide is specific to floor moisture problems and solutions,
refer to the most current editions of both ACI 302.1R, “Guide for Concrete
Floor and Slab Construction,” and ACI 360R, “Design of Slabs-onGround,”
for general information. These two documents contain guidance
on floor design and construction that is needed to achieve successful floor
covering performance.
Keywords: admixtures; cracking; curing; curling; drying; mixture proportioning;
moisture movement; moisture test; relative humidity; slab-onground;
specifications; vapor retarder/barrier.
[-] The following 12 users Like gulilero's post:12 users Like gulilero's post
  • ykhackhack, kowheng, subin91, blaze, david-smith, Dell_Brett, vvvv, isurya, fbx_rdnk, st77bel, bigone, klsamy77
05-02-2023, 09:09 AM
ACI PRC-302.2-22: Concrete Slabs that Receive Moisture-Sensitive Flooring Materials - Guide
Author(s)/Editor(s): ACI Committee 302 | Size: 7.19 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 49 | ISBN: 9781641952064
[Image: 33809506185561480195.png]
This guide contains materials, design, and construction recommendations for concrete slabs-on-ground and suspended slabs that are to receive moisture-sensitive flooring materials. These flooring materials include sheet rubber, epoxy coatings, vinyl composition tile, sheet vinyl, carpet, athletic flooring, laminates, and hardwood.
admixtures; cracking; curing; curling; drying; mixture proportioning; moisture movement; moisture test; relative humidity; slabs-on-ground; specifications; vapor retarder.
  • zrilek, babakfeyzi, rami1976, Dell_Brett, milova, PinkPant
  ACI SP-357: Punching Shear of Concrete Slabs: Insights from New Materials, Tests, and poolmand 0 1,459 03-04-2024, 08:06 AM
  ACI 544.12: Performance-Based Fiber-Reinforced Concrete for Slabs-on-Ground and Overl poolmand 0 1,894 01-23-2024, 05:36 AM
  ACI 447R-18 Design Guide for Twisting Moments in Slabs sabooryan 2 2,478 05-09-2023, 08:19 AM
  ACI SCM-25: Concrete Slabs on Ground Solution 6 6,895 05-08-2023, 07:02 AM
  ACI 421.1: Guide for Shear Reinforcement for Slabs poolmand 1 1,908 10-17-2021, 10:18 AM
  Fib 81 ACI SP-315 Punching shear of structural concrete slabs sabooryan 2 2,217 04-12-2021, 12:52 PM
