Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Self-Compacting Concrete (SCC) for Prestressed Bridge Girders
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-10-2012, 02:22 PM
Author: Erkmen, Bulent | Size: 4.18 MB | Format: PDF | Quality: Original preprint | Publisher: University of Minnesota, Twin Cities | Year: 2008 | pages: 347
[Image: 39435742919239563061.png]
Researchers conducted an experimental program to investigate the viability of producing self-consolidating concrete (SCC) using locally available aggregate, and the viability of its use in the production of precast prestressed concrete bridge girders for the State of Minnesota. Six precast prestressed bridge girders were cast using four SCC and two conventional concrete mixes. Variations in the mixes included cementitious materials (ASTM Type I and III cement and Class C fly ash), natural gravel and crushed stone as coarse aggregate, and several admixtures. The girders were instrumented to monitor transfer length, camber, and prestress losses. In addition, companion cylinders were cast to measure the compressive strength and modulus of elasticity, and to monitor the creep and shrinkage over time. The viability of using several test methods to evaluate SCC fresh properties was also investigated. The test results indicated that the overall performance of the SCC girders was comparable to that of the conventional concrete girders. The measured, predicted, and calculated prestress losses were generally in good agreement. The study indicated that creep and shrinkage material models developed based on companion cylinder creep and shrinkage data can be used to reasonably predict measured prestress losses of both conventional and SCC prestressed bridge girders.
  • kowheng, blaze, Jackass, Dell_Brett, amritarao
  The Cantilever Construction of Prestressed Concrete Bridges taifur 0 1,790 04-14-2018, 04:52 PM
Last Post: taifur
  Prestressed Concrete Bridges: Design and Construction abudabeeja 10 10,770 03-28-2017, 12:20 AM
Last Post: gulilero
  Construction and Design of prestressed Concrete segmental Bridges ziggywas1 4 5,200 03-30-2016, 07:30 AM
Last Post: subin91
  Prestressed concrete: Design and construction toa011 2 4,287 03-04-2015, 10:37 AM
  Prestressed concrete bridges - by Christian Menn toa011 7 6,175 07-24-2013, 07:42 PM
Last Post: axcel
  Modern prestressed concrete highway bridge superstructures lamkin 4 5,024 01-24-2013, 12:11 PM
Last Post: shadabg
  PCI BridgeManual: Precast, Prestressed Concrete Bridges-The High Performance Solution mowafi3m 3 4,052 12-06-2012, 10:26 AM
Last Post: ssobhan
