Civil Engineering Association eBooks Structural Books Concrete Allowable Compressive Stress at Prestress Transfer
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-10-2012, 02:14 PM (This post was last modified: 11-10-2012, 02:17 PM by mahyarov.)
Author: Schnittker, Brian University of Texas, Austin Bayrak, Oguzhan University of Texas, Austin | Size: 7.94 MB | Format: PDF | Quality: Original preprint | Publisher: University of Texas, Austin | Year: 2008 | pages: 206
[Image: 64289763213844542095.png]
In 2004, the Texas Department of Transportation (TxDOT) initiated Project 5197 to investigate the feasibility of increasing the allowable compressive stress limit at prestress transfer. Initially, the live load performance of 36 specimens was evaluated by Birrcher and Bayrak (TxDOT Report 5197-1, 2007). Report 5197-4 presents the subsequent research conducted based on recommendations of Birrcher and Bayrak (2007). In this portion of TxDOT Project 5197, 45 Type-C beams and 10 4B28 box beams were tested to experimentally determine their cracking load. The Type-C beams were produced in four different fabrication plants using conventionally consolidated concrete. The 10 4B28 box beams were produced in two fabrication plants using concrete mixture designs of both self consolidating concrete as well as conventional concrete. For all specimens, measured cracking loads were compared to predicted cracking loads. The data from the 45 Type-C beams and 10 box beams were added to the 36 beams investigated by Birrcher and Bayrak (2007) to compile a comprehensive set of data from 91 specimens. An appropriate maximum compressive stress limit was determined from the ability to accurately predict the load at which cracking occurred. As the maximum compressive stress at prestress transfer was increased, a decline in cracking load prediction accuracy was observed. For the specimens subjected to high compressive stresses at release (greater than 0.65f’ci), the concrete in the pre-compressed tensile zone was subjected to the non-linear inelastic range causing microcracking to occur. This non-linear behavior (due to microcracking) was unaccounted for in prestress losses or standard design equations (P/A±Mc/I). Based on the analysis of the results, an increase of the allowable compressive stress limit at prestress transfer to 0.65f’ci is justified. Additionally, the use of self consolidating concrete with a maximum compressive stress of 0.65f’ci is not recommended.
  • kowheng, blaze, Jackass, chenamoy, sodapas, Dell_Brett
  Effects of Increasing the Allowable Compressive Stress at Release on the Shear Streng mahyarov 0 1,273 11-10-2012, 02:25 PM
Last Post: mahyarov
