Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Steel Fiber Replacement of Mild Steel in Prestressed Concrete Beams
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-10-2012, 01:58 PM
Author: Tadepalli, Padmanabha Rao University of Houston Hoffman, Norman University of Houston Hsu, Thomas T C University of Houston Mo, Y L University of Houston | Size: 8.96 MB | Format: PDF | Quality: Original preprint | Publisher: University of Houston | Year: 2011 | pages: 192
[Image: 40235217626843107722.png]
In traditional prestressed concrete beams, longitudinal prestressed tendons serve to resist bending moment and transverse mild steel bars (or stirrups) are used to carry shear forces. However, traditional prestressed concrete I-beams exhibit early-age cracking and brittle shear failure at the end zones despite the use of a high percentage of stirrups (4.2%). Moreover, producing and placing stirrups require costly labor and time. To overcome these difficulties, it is proposed to replace the stirrups in prestressed concrete beams with steel fibers. This replacement concept was shown to be feasible in a Texas Department of Transportation (TxDOT) project (TxDOT project 0-4819) recently completed at the University of Houston. The replacement of stirrups by steel fibers in highway beams requires a set of shear design provisions and guidelines for Prestressed Steel Fiber Concrete (PSFC) beams. The development of rational shear provisions with wide applications must be guided by a mechanics-based shear theory and must be validated by experimental tests on I- and box-beams. A rational shear theory, called the Softened Membrane Model (SMM), has been developed at the University of Houston for reinforced concrete beams. This theory satisfies Navier’s three principles of mechanics of materials, namely, stress equilibrium, strain compatibility and the constitutive relationship between stress and strain for the materials. The first phase of the research consisted of testing 10 full-size PSFC panels. This was done to establish the effect of fiber factor and the level of prestress on the constitutive models of steel fiber concrete and prestressing tendons. From the data a set of constitutive models was developed to predict the behavior of PSFC. Notable findings include the fact that increasing steel fiber content has a beneficial effect on the softening properties of PSFC. Additionally, the findings show that increasing steel fiber content increases tension stiffening in prestressed PSFC under tensile loading. The second phase of this research project generalizes the SMM shear theory for application to PSFC beams. This was achieved by feeding the new constitutive models of fiber concrete and prestressing tendons into a finite element program (OpenSees). The accuracy of the new shear theory was evaluated by testing full-size PSFC I- and box-beams that fail in shear modes. The developed finite element program was used to simulate the shear behavior of the beams with acceptable accuracy. Finally, a design equation and recommendations were provided for use when designing PSFC beams. Using the design equations, a series of four design examples was also provided.
  • kowheng, blaze, oanm2000, Dell_Brett, amritarao
  Prestressed Steel Bridges, Theory and Design toa011 3 4,243 08-19-2018, 10:01 AM
Last Post: Kurucz
  The Cantilever Construction of Prestressed Concrete Bridges taifur 0 1,797 04-14-2018, 04:52 PM
Last Post: taifur
  Prestressed Concrete Bridges: Design and Construction abudabeeja 10 10,779 03-28-2017, 12:20 AM
Last Post: gulilero
  Construction and Design of prestressed Concrete segmental Bridges ziggywas1 4 5,217 03-30-2016, 07:30 AM
Last Post: subin91
  Seismic Design Aids for Nonlinear Pushover Analysis of Reinforced Concrete and Steel lamkin 12 8,085 11-23-2015, 03:22 PM
Last Post: ibg0203
  Steel Bridges - Conceptual and Structural Design of Steel and Steel-Concrete Composit ssobhan 5 4,287 09-23-2015, 06:06 AM
Last Post: hodzicemir
  Prestressed concrete: Design and construction toa011 2 4,300 03-04-2015, 10:37 AM
