Civil Engineering Association eBooks Structural Books Concrete Preparation and Testing of Drilled Shafts with Self-Consolidating Concrete
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-10-2012, 08:05 AM
Author: Ozyildirim, H Celik Sharp, Stephen R | Size: 1.20 MB | Format: PDF | Quality: Original preprint | Publisher: Virginia Center for Transportation Innovation and Research | Year: 2012 | pages: 36
[Image: 59131062107915451222.png]
In this study, self-consolidating concrete (SCC) was evaluated in drilled shafts and the integrity of drilled shafts was determined using cross-hole sonic logging (CSL), a low-strain nondestructive integrity testing technique. SCC has very high flowability. It was placed in the drilled shafts of the bridge on Route 28 over Broad Run in Bristow in Prince William County, Virginia. There were two bridges at the site; the one carrying the northbound traffic had drilled shafts using conventional concrete with high consistency (i.e., flowability). Half of the shafts of the bridge carrying the southbound traffic were cast with SCC. During placement, properties of the fresh concrete were tested and specimens were prepared to determine the hardened properties. The integrity of the shafts within the reinforcing cage was determined using CSL, with sonic echo/impulse response also used to evaluate several test shafts. The use of acousto-ultrasonic (AU) measurements to determine the cover depth outside the reinforcing cage was also evaluated during laboratory testing. In addition to the Route 28 shafts, three test shafts with conventional and SCC concretes were cast in an area headquarters. These shafts had intentional voids created through the use of sand bags and Styrofoam to investigate further the ability of the nondestructive test equipment. The results indicated that SCC is highly desirable for drilled shafts; it flows easily, filling the hole, and the removal of the temporary casing is facilitated by this highly workable material. CSL is a satisfactory nondestructive method to determine the integrity of shafts. Sonic echo/impulse response also showed promise as a method that complements CSL for determining the integrity of a shaft.
[-] The following 7 users Like mahyarov's post:7 users Like mahyarov's post
  • blaze, knrsa, p_vosoughi, kowheng, Jackass, Dell_Brett, amritarao
  Self-consolidating concrete : applying what we know ir_71 1 1,956 06-07-2016, 03:15 PM
Last Post: scorpion07
  NCHRP R628: Self-Consolidating Concrete for Precast, Prestressed Concrete Bridge... datagap 2 2,471 08-08-2014, 06:59 PM
Last Post: r3be1
  Design, Production and Placement of Self-Consolidating Concrete: Proceedings of SCC20 cace-01 7 4,641 09-11-2013, 12:12 PM
Last Post: axcel
  Prestress Losses in Prestressed Bridge Girders Cast with Self-Consolidating Concrete mahyarov 0 1,469 11-10-2012, 03:23 PM
Last Post: mahyarov
  High-Strength Self-Consolidating Concrete Girders Subjected To Elevated Compressive F mahyarov 0 1,410 11-10-2012, 02:10 PM
Last Post: mahyarov
  Aggregate Distribution Investigation in Box Beams Fabricated with Self Consolidating mahyarov 0 1,339 11-10-2012, 02:08 PM
Last Post: mahyarov
  Performance of Self-Consolidating Concrete in Prestressed Girders mahyarov 0 1,472 11-10-2012, 02:04 PM
Last Post: mahyarov
