Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Cross-Frame Connection Details for Skewed Steel Bridges
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-07-2012, 02:43 PM
Author: Quadrato, Craig | Size: 15.01 MB | Format: PDF | Quality: Original preprint | Publisher: University of Texas, Austin | Year: 2010 | pages: 411
[Image: 28797047165174428783.png]
This report documents a research investigation on connection details and bracing layouts for stability bracing of steel bridges with skewed supports. Cross-frames and diaphragms play an important role in stabilizing steel girders, particularly during construction. The commonly used bent plate connection between skewed braces and steel girders can introduce flexibility that can have detrimental effects on the bracing behavior. An alternative detail investigated in this study is a split pipe stiffener used to connect cross-frames to girders at a skew. The split pipe stiffener allows perpendicular connections to the cross-frame connection tab, regardless of the skew angle. The split pipe provides a stiffer connection between the cross-frame and the girder. More importantly, the split pipe stiffener increases the torsional stiffness of the girder by introducing substantial warping restraint. This increases the lateral torsional buckling capacity of the girder and allows the first line of intermediate cross-frames to be moved farther from the support. Overall, the increase in girder torsional stiffness and buckling capacity that results from the use of the split pipe stiffener will enhance the safety of the girder at all stages of construction: during transportation, lifting, erection, and placement of the concrete deck. This study also examined layout patterns for intermediate cross-frames in skewed bridges. Results showed that staggering the intermediate cross-frames reduces live load induced forces in the cross-frame members and mitigates the potential for associated fatigue cracking. This report also provides design recommendations for the split pipe stiffener and provides a procedure for computing the buckling capacity of girders with split pipe stiffeners.
[-] The following 7 users Like mahyarov's post:7 users Like mahyarov's post
  • blaze, warbeast, carolinandra, kowheng, malc, oanm2000, eliseo.as
  Design of Modern Steel Railway bridges melkat 3 5,077 02-06-2019, 04:29 AM
  The Design of Modern Steel Bridges by Sukhen Chatterjee Flexi 8 6,160 10-08-2018, 04:54 PM
Last Post: febo927
  Prestressed Steel Bridges, Theory and Design toa011 3 4,241 08-19-2018, 10:01 AM
Last Post: Kurucz
  Design and Construction of Modern Steel Railway Bridges asim99 0 1,781 08-18-2017, 11:04 PM
Last Post: asim99
  Steel Bridges - Conceptual and Structural Design of Steel and Steel-Concrete Composit ssobhan 5 4,286 09-23-2015, 06:06 AM
Last Post: hodzicemir
  Fatigue Life of Riveted Steel Bridges lamkin 5 3,717 08-14-2014, 08:05 PM
Last Post: r3be1
  Design of Steel-Concrete Composite Bridges to Eurocodes ir_71 3 3,925 07-30-2014, 09:19 AM
Last Post: apocalipse
