Civil Engineering Association eBooks Structural Books Concrete External Post-Tensioning Anchorage
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
11-07-2012, 02:33 PM
Author: El-Zghayar, Elie A | Size: 6.28 MB | Format: PDF | Quality: Original preprint | Publisher: University of Central Florida, Orlando | Year: 2011 | pages: 147
[Image: 77057222866425379272.png]
Post-tensioning tendons in segmental bridge construction are often only anchored within the deviator and pier segments. The effectiveness of the post-tensioning (PT) system is therefore dependent on proper functioning of the anchorages. On August 28, 2000, a routine inspection of the Mid-Bay Bridge (Okaloosa County, Florida) revealed corrosion in numerous PT tendons. Moreover, one of the 19-strand tendons was completely slacked, with later inspection revealing a corrosion-induced failure at the pier anchor location. Anchorage failure caused all PT force to transfer to the steel duct located within the pier segment that in turn slipped and caused the tendon to go completely slack. After the application of PT force, the anchorage assembly and steel pipes that house the tendon are filled with grout. These short grouted regions could, in the event of anchorage failure, provide a secondary anchorage mechanism preventing the scenario mentioned above from occurring. This paper presents the results of a full-scale experimental investigation on anchorage tendon pullout. The study focuses on the length required to develop the in-service PT force within the pier segment grouted steel tube assembly. Seven, twelve, and nineteen 0.6 inch diameter strand tendons with various development lengths were considered. Recommendations for pier section pipe detailing and design will be discussed.
[-] The following 13 users Like mahyarov's post:13 users Like mahyarov's post
  • blaze, gulilero, SCREAM7890, tomtumx, kowheng, triance, skyscraper, tang1942, chenamoy, vvvv, malc, viet2010, sacem
  Post-Tensioning in Building Construction TAFATNEB 0 2,993 03-21-2023, 08:18 AM
  PTI Post-tensioning Manual 6th ed 2006 user 4 6,454 05-26-2021, 06:39 PM
Last Post: deviationz
  FIB 7: Corrugated plastic ducts for internal bonded post-tensioning arshiakh 2 2,206 12-17-2018, 04:55 PM
Last Post: Nita1391
  VSL Post-Tensioning Systems gianniorlati 1 1,913 08-12-2018, 03:46 AM
Last Post: gulilero
  Post-Tensioning Manual RyanRS 0 1,573 03-21-2016, 10:24 AM
Last Post: RyanRS
  Anchorage in Concrete Construction hich 5 4,274 09-19-2015, 03:15 PM
Last Post: ibg0203
  PCA: Strength Design of Anchorage to Concrete oscargon 1 2,564 08-29-2014, 02:39 PM
Last Post: r3be1
