Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Behavior and Design Guidelines for Steel Frame Structures with Added Viscoela
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
11-05-2012, 08:39 PM (This post was last modified: 11-18-2014, 05:45 PM by usman.)
Seismic Behavior and Design Guidelines for Steel Frame Structures with Added Viscoelastic Dampers
Author: K.C. Chang, M.L. Lai, T.T. Soong, D.S. Hao and Y.C. Yeh | Size: 32.6 MB | Format: PDF | Quality: Scanner | Publisher: NCEER | Year: 1993 | pages: 110 | ISBN: Technical Report NCEER-93-0009
[Image: 69663116202163871444.jpg]
ABSTRACT
In order to determine the effectiveness of adding viscoelastic dampers to structures on the reduction of their seismic response, a comprehensive analytical and experimental program
was carried out. The experimental program was first conducted on a 2/5-scale five-story steel frame under precisely controlled ambient temperatures and subject to simulated ground motions with peak accelerations ranging from 0.12g to 0.60g. Results show that viscoelastic dampers are very effective in attenuating seismic structural response at all levels of earthquake ground motions, and that their energy dissipation capacity decreases as ambient temperature increases. However, they are effective at all temperatures tested in the research program. A rational seismic design procedure for viscoelastically damped structure is developed based on these results.
Further tests using a full-scale prototype structure confirm that damping in the full-scale structure can be significantly increased by adding relatively small viscoelastic dampers. The damper design procedure developed based on the scaled model can also be applied to the full-scale structure. This full-scale analytical and experimental study provides an important base for applying the extensive data generated from the scaled model testing to the full-scale structures.
TABLE OF CONTENTS
Section
1 INTRODUCTION......................................................................... 1-1
2 DYNAMIC CHARACTERISTICS OF VISCOELASTIC DAMPERS........... 2-1
3 SEISMIC TESTS OF VISCOELASTICALLY DAMPED STRUCTURE............. 3-1
4 ANALYTICAL SiMULATIONS '........ 4-1
5 DESIGN OF STRUCTURES WITH ADDED VISCOELASTIC
6 FULL-SCALE STRUCTURAL TESTS.................................................. 6-1
7 SUMMARy................................................................................. 7-1
8 REFERENCES. . ... . .. ... .. .. .. .. ... .. .. .. ... .. .. .. .. ... .. .. .. .. . .. .. .. .. ... .. .. .. .... ... . 8-1
The protective and intelligent systems program constitutes one of the important areas of research
in the Building Project. Current tasks include the following:
1. Evaluate the performance of full-scale active bracing and active mass dampers already in place in terms of performance, power requirements, maintenance, reliability and cost.
2. Compare passive and active control strategies in. terms of structural type, degree of effectiveness, cost and long-term reliability.
3. Perform fundamental studies of hybrid control.
4. Develop and test hybrid control systems.
NCEER's activities in viscoelastic dampers research for seismic applications began in 1987 with analytical and experimental work carried out at the State University of New York at Buffalo and at the University of California at Berkeley. The ultimate aim is to determine their effectiveness when incorporated into a structure under seismic loads, and to develop a rational design procedure for such structures. This report summarizes results of a comprehensive analytical and experimental program for steel frame structures. The experimental program was first conducted on a 215-scale steel frame in the laboratory, followed by verification tests conducted on a full-scale prototype structure. A rational seismic design procedure for viscoelastically damped steel frame structures is developed based on these results.
[-] The following 19 users Like david-smith's post:19 users Like david-smith's post
  • ISTRAKTURA, malc, gulilero, kowheng, aslam, Dell_Brett, shadabg, warbeast, pezhmankhan, cace-01, oanm2000, mgdario, bigone, Sumatra, Wijono, mahyarov, devilmaycry, jcbv, K.Lee
Likes: 12,073 in 1,233 posts
11-18-2014, 02:48 PM
[-] The following 12 users Like pezhmankhan's post:12 users Like pezhmankhan's post
  • PinkPant, amindoxiti, zrilek, oanm2000, jcbv, Dell_Brett, bridgeengineer, malc, carolinandra, bigone, ssobhan, levanduy
05-07-2019, 04:11 AM
Size: 34.3 MB | Format: PDF
[-] The following 19 users Like kowheng's post:19 users Like kowheng's post
  • subin91, jcbv, zrilek, Dell_Brett, febo927, pedzaquino, jcoronellr, PinkPant, oanm2000, amindoxiti, caifan, K.Lee, cace-01, cristi, ajmf77, spat, blaze, melekeen, lasalleguy
Away  bridgeengineer
Semi Senior Member
Banned
Poland
User ID: 93214
Threads: 49
Likes: 1,023 in 110 posts
Given Likes: 4769
12-20-2022, 07:30 PM
please reupload
thanks
  Advanced Design Examples of Seismic Retrofit of Structures sabooryan 2 4,115 07-08-2024, 05:38 AM
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 2,878 06-28-2024, 02:32 PM
  Seismic Design Methods for Steel Building Structures poolmand 0 1,480 01-01-2023, 10:14 AM
  Displacement Based Seismic Design of Structures Grunf 13 11,396 02-21-2022, 06:37 PM
Last Post: ersin
  Textbook of Seismic Design - Structures, Piping Systems, and Components subin91 1 2,137 09-17-2019, 10:16 AM
  NCHRP R611: Seismic Analysis and Design of Retaining Walls, Buried Structures, Slopes kowheng 1 2,686 05-11-2019, 04:12 AM
  TBI: Guidelines for Performance-Based Seismic Design of Tall Buildings pezhmankhan 1 3,002 05-11-2019, 03:49 AM
