Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Engineering Policy Guidelines for Design of Earth Slopes
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-30-2012, 08:07 AM
Author: Loehr, J Erik | Size: 616 KB | Format: PDF | Quality: Original preprint | Publisher: Missouri University of Science and Technology, Rolla | Year: 2011 | pages: 21
[Image: 70142914132994129084.png]
These guidelines were developed as part of a comprehensive research program undertaken by the Missouri Department of Transportation (MoDOT) to reduce costs associated with design and construction of bridge foundations while maintaining appropriate levels of safety for the traveling public. The guidelines were established from a combination of existing MoDOT Engineering Policy Guide (EPG) documents, from the 4th Edition of the AASHTO LRFD Bridge Design Specifications with 2009 Interim Revisions, and from results of the research program. Some provisions of the guidelines represent substantial changes to current practice to reflect advancements made possible from results of the research program. Other provisions were left essentially unchanged, or were revised to reflect incremental changes in practice, because research was not performed to address those provisions. Some provisions reflect rational starting points based on judgment and past experience from which further improvements can be based. All of the provisions should be considered as “living documents” subject to further revision and refinement as additional knowledge and experience is gained with the respective provisions. A number of specific opportunities for improvement are provided in the commentary that accompanies the guidelines.
[-] The following 8 users Like mahyarov's post:8 users Like mahyarov's post
  • kowheng, cace-01, Albert, oanm2000, malc, harsono, davegabj, alibouafia
  Earth Pressure and Earth-Retaining Structures, 3th Ed. odiclas 4 3,751 06-10-2021, 07:39 AM
  The Stability of Slopes isurya 5 4,116 06-15-2018, 08:32 PM
Last Post: axcel
  Limit Equilibrium and FE Analysis of Slopes gianniorlati 2 2,309 11-25-2015, 10:09 AM
Last Post: 3fan
  Engineering Policy Guidelines For Design Of Spread Footings mahyarov 1 1,898 10-30-2012, 05:39 AM
Last Post: shadabg
  Engineering Policy Guidelines For Design Of Driven Piles mahyarov 0 1,690 10-29-2012, 07:23 AM
Last Post: mahyarov
  Engineering Policy Guidelines For Design Of Drilled Shafts mahyarov 0 1,534 10-29-2012, 07:22 AM
Last Post: mahyarov
  Seismic Analysis and Design of Retaining Walls, Buried Structures, Slopes, and Embank mahyarov 0 1,741 10-23-2012, 06:10 PM
Last Post: mahyarov
