Civil Engineering Association eBooks Traffic Engineering Effective Shoulder Design and Maintenance
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 08:27 PM
Author: White, David J | Size: 11.95 MB | Format: PDF | Quality: Original preprint | Publisher: Iowa State University, Ames | Year: 2007 | pages: 296
[Image: 60324813837248988206.png]
Granular shoulders are an important element of the transportation system and are constantly subjected to performance problems due to wind- and water-induced erosion, rutting, edge drop-off, and slope irregularities. Such problems can directly affect drivers’ safety and often require regular maintenance. The present research study was undertaken to investigate the factors contributing to these performance problems and to propose new ideas to design and maintain granular shoulders while keeping ownership costs low. This report includes observations made during a field reconnaissance study, findings from an effort to stabilize the granular and subgrade layer at six shoulder test sections, and the results of a laboratory box study where a shoulder section overlying a soft foundation layer was simulated. Based on the research described in this report, the following changes are proposed to the construction and maintenance methods for granular shoulders: (1) A minimum California bearing ratio (CBR) value for the granular and subgrade layer should be selected to alleviate edge drop-off and rutting formation; (2) For those constructing new shoulder sections, the design charts provided in this report can be used as a rapid guide based on an allowable rut depth. The charts can also be used to predict the behavior of existing shoulders; and (3) In the case of existing shoulder sections overlying soft foundations, the use of geogrid or fly ash stabilization proved to be an effective technique for mitigating shoulder rutting.
[-] The following 7 users Like mahyarov's post:7 users Like mahyarov's post
  â€˘ mbakr, sodapas, cace-01, kowheng, isurya, oanm2000, Mohammad6299
  Low-Volume Road Engineering: Design, Construction, and Maintenance rami1976 2 3,211 07-12-2018, 08:29 PM
  Sustainable Transportation Systems: Planning, Design, Build, Manage, and Maintenance Mohammad6299 2 2,459 03-29-2017, 08:31 AM
Last Post: cace-01
  Highways: The Location, Design, Construction and Maintenance of Road Pavements abudabeeja 6 5,199 06-19-2016, 09:57 AM
  Impact of Shoulder Width and Median Width on Safety mahyarov 0 1,242 10-23-2012, 04:59 PM
Last Post: mahyarov
  Guidance for the Design and Application of Shoulder and Centerline Rumble Strips mahyarov 0 1,284 10-23-2012, 04:35 PM
Last Post: mahyarov
  NCHRP - R727 Effective Experiment Design and Data Analysis in Transportation Research mahyarov 0 1,402 10-23-2012, 05:55 AM
Last Post: mahyarov
  Gravel roads : maintenance and design manual abudabeeja 2 3,148 03-03-2012, 12:58 PM
