Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Geosynthetic Reinforced Soil for Low-Volume Bridge Abutments
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 07:35 PM
Author: Vennapusa, Pavana Iowa State University, Ames White, David Klaiber, Wayne Iowa State University, Ames Wang, Shiyun | Size: 15.32 MB | Format: PDF | Quality: Original preprint | Publisher: Iowa State University, Ames | Year: 2012 | pages: 132
[Image: 17217721975580842822.png]
This report presents a review of literature on geosynthetic reinforced soil (GRS) bridge abutments, and test results and analysis from two field demonstration projects (Bridge 1 and Bridge 2) conducted in Buchanan County, Iowa, to evaluate the feasibility and cost effectiveness of the use of GRS bridge abutments on low-volume roads (LVRs). The two projects included GRS abutment substructures and railroad flat car (RRFC) bridge superstructures. The construction costs varied from $43k to $49k, which was about 50 to 60% lower than the expected costs for building a conventional bridge. Settlement monitoring at both bridges indicated maximum settlements ≤1 in. and differential settlements ≤ 0.2 in transversely at each abutment, during the monitoring phase. Laboratory testing on GRS fill material, field testing, and in ground instrumentation, abutment settlement monitoring, and bridge live load (LL) testing were conducted on Bridge 2. Laboratory test results indicated that shear strength parameters and permanent deformation behavior of granular fill material improved when reinforced with geosynthetic, due to lateral restraint effect at the soil-geosynthetic interface. Bridge LL testing under static loads indicated maximum deflections close to 0.9 in and non-uniform deflections transversely across the bridge due to poor load transfer between RRFCs. The ratio of horizontal to vertical stresses in the GRS fill was low (< 0.25), indicating low lateral stress on the soil surrounding GRS fill material. Bearing capacity analysis at Bridge 2 indicated lower than recommended factor of safety (FS) values due to low ultimate reinforcement strength of the geosynthetic material used in this study and a relatively weak underlying foundation layer. Global stability analysis of the GRS abutment structure revealed a lower FS than recommended against sliding failure along the interface of the GRS fill material and the underlying weak foundation layer. Design and construction recommendations to help improve the stability and performance of the GRS abutment structures on future projects, and recommendations for future research are provided in this report.
[-] The following 3 users Like mahyarov's post:3 users Like mahyarov's post
  • cace-01, Evandrojr, kowheng
  Design and Construction Guidelines for GRS Bridge Abutments with a Flexible Facing mahyarov 0 1,490 10-25-2012, 06:12 PM
Last Post: mahyarov
