Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics GEOTECHNICAL ENGINEERING CIRCULAR NO. 4: GROUND ANCHORS AND ANCHORED SYSTEMS
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 06:20 PM
Author: Sabatini, P J Pass, D G Bachus, R C | Size: 4.51 MB | Format: PDF | Quality: Original preprint | Publisher: GeoSyntec Consultants | Year: 1999 | pages: 312
[Image: 43779147075172843829.png]
This document presents state-of-the-practice information on the design and installation of cement-grouted ground anchors and anchored systems for highway applications. The anchored systems discussed include flexible anchored walls, slopes supported using ground anchors, landslide stabilization systems, and structures that incorporate tiedown anchors. This document draws extensively from the FHWA-DP-68-IR (1988) design manual in describing issues such as subsurface investigation and laboratory testing, basic anchoring principles, ground anchor load testing, and inspection of construction materials and methods used for anchored systems. This document provides detailed information on design analyses for ground anchored systems. Topics discussed include selection of design earth pressures, ground anchor design, design of corrosion protection system for ground anchors, design of wall components to resist lateral and vertical loads, evaluation of overall anchored system stability, and seismic design of anchored systems. Also included in the document are two detailed design examples and technical specifications for ground anchors and for anchored walls.
  • blaze, ruaumoko, Evandrojr, kowheng, pmg814, Trishu999
  Fundamentals of Ground Improvement Engineering poolmand 0 2,797 09-06-2021, 07:44 AM
  Pressuremeter Testing: Methods and Interpretation (CIRIA Ground Engineering Report) axcel 1 1,700 04-25-2018, 10:17 PM
Last Post: gulilero
  Frozen Ground Engineering, 2nd edition asim99 2 2,792 09-17-2015, 05:22 AM
Last Post: Kerry
  Recommended Practice for Evaluation of Metal-Tensioned Systems in Geotechnical Applic mahyarov 0 1,548 10-24-2012, 10:44 AM
Last Post: mahyarov
