Civil Engineering Association eBooks Structural Books Concrete Seismic, Creep, and Tensile Testing of Various Epoxy Bonded Rebar Products in Hardene
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 03:53 PM
Seismic, Creep, and Tensile Testing of Various Epoxy Bonded Rebar Products in Hardened Concrete
Author: Meline, Robert J Gallaher, Malinda Duane, Jacob | Size: 2.32 MB | Format: PDF | Quality: Unspecified | Publisher: California Department of Transportation | Year: 2006 | pages: 110
[Image: 01751956615186303225.png]
The objective of this project was to evaluate the performance of currently specified epoxy adhesive anchor systems on various epoxy-coated rebar under seismic, creep and tensile loading. The epoxy-coated rebar was found to meet the requirements of ICBO-AC58, Section 5.3.7.2.4, for tension and seismic loading when bonded into hardened concrete using an epoxy adhesive but not the Caltrans Augmentation/Revisions for creep loading when bonded into hardened concrete. The rebar bonded with Covert Operations CIA-Gel 7000 was found to meet the creep requirements, whereas the rebar bonded with Simpson SET22 and Red Head Epcon C6 did not meet the conditions of acceptance for creep loading. It was also noticed that, when compared to the manufacturer test data, the epoxy-coated rebar outperformed uncoated rebar in allowable tensile loads for two of the three epoxies tested. Simpson SET22 adhesive under performed the manufacturer test data. In the Revision to this report in 2007, further review of the creep data for the rebar bonded with Simpson SET determined that the adhesive met the creep requirement. Due to the load fluctuations, only the first 26 days of data were used for the logarithmic curve fit.
  • blaze, cace-01, kowheng, malc, ykhackhack
  Repair and Rehabilitation of Bridge Components Containing Epoxy-Coated Reinforcement mahyarov 0 1,405 10-25-2012, 06:28 PM
Last Post: mahyarov
