Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) A Precast Concrete Bridge Bent Designed to Re-Center After an Earthquake
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 02:50 PM
Author: Cohagen, Laila | Size: 2.97 MB | Format: PDF | Quality: Original preprint | Publisher: University of Washington, Seattle | Year: 2008 | pages: 131
[Image: 62575572101337937850.png]
In this study the post-earthquake residual displacements of reinforced concrete bridge bents were investigated. The system had mild steel that was intended to dissipate energy and an unbonded, post-tensioned tendon that was supposed to remain elastic and re-center the column. The columns tested had different mild steel to prestress ratios, which affected their re-centering ability. A re-centering ratio developed by Hieber (2005), which took into account the external axial load, initial prestress force, and the mild steel ratio, was used to predict these re-centering capabilities. Two 40 percent scale specimens with large-bar connection details and a central unbonded, post-tensioned tendon were tested by using pseudo-static loading. The large-bar system is a rapidly constructible precast system for use in seismic regions. The test columns had re-centering ratios of 1.6 and 1.2. A column with the same connection details but no prestress and a re-centering ratio of 0.9 was used as reference. The displacement at zero force in the test was used as a proxy for the residual displacement after an earthquake. The tests showed that columns with a larger re-centering ratio did experience lower residual drifts, although this distinction only became clear for drift ratios that exceeded 2 percent. The tests also showed that increases in post-tensioning force led to slight increases in damage at high drift ratios.
  • blaze, cace-01, kowheng, malc
  PRECAST CONCRETE BOX CULVERTS rami1976 0 1,566 10-24-2015, 01:14 PM
  FIB 29: Precast concrete bridges lamkin 6 4,704 02-07-2015, 06:53 PM
  Precast Balanced Cantilever Bridge Design Using AASHTO LRFD Design Specifications subin91 0 2,073 11-25-2013, 10:43 AM
Last Post: subin91
  PCI BridgeManual: Precast, Prestressed Concrete Bridges-The High Performance Solution mowafi3m 3 4,053 12-06-2012, 10:26 AM
Last Post: ssobhan
  Application of Precast Decks and Other Elements to Bridge Structures mahyarov 0 2,070 11-13-2012, 10:40 AM
Last Post: mahyarov
  Characterization of Self-Consolidating Concrete for Design of Precast, Prestressed Br mahyarov 0 1,440 11-10-2012, 02:19 PM
Last Post: mahyarov
  Prefabricated/Precast Bridge Elements and Systems (PBES) for O-System Bridges mahyarov 0 1,585 11-10-2012, 07:46 AM
Last Post: mahyarov
