Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Retrofit of Cruciform-Shaped Columns in the Aurora Avenue Bridge Using FRP Wr
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 02:13 PM
Seismic Retrofit of Cruciform-Shaped Columns in the Aurora Avenue Bridge Using FRP Wrapping
Author: McLean, David I Washington State University, Pullman Walkenhauer, Brian J Washington State University | Size: 18.31 MB | Format: PDF | Quality: Unspecified | Publisher: Washington State University, Pullman | Year: 2010 | pages: 96
[Image: 12137982209599805152.png]
Experimental tests were conducted on seven 1/3-scale column specimens to evaluate the vulnerabilities of existing cruciform-shaped columns and to develop appropriate retrofit measures that address the identified vulnerabilities. The specimens represented both solid and split columns in the Aurora Avenue Bridge in Seattle, Washington. The as-built specimens failed at low ductility levels due to shear distress. Fiber reinforced polymer (FRP) jackets with FRP inserts to anchor the jackets in the column reentrant corners along with steel confinement collars to provide confinement in the hinging regions were used to retrofit the column specimens. The retrofitted specimens developed plastic hinging in the column, with enhanced strength, energy and ductility capacities. Guidelines were presented for designing the various components of the retrofit measures.
  • blaze, cace-01, kowheng, mgdario
  Advanced Design Examples of Seismic Retrofit of Structures sabooryan 2 4,046 07-08-2024, 05:38 AM
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 2,833 06-28-2024, 02:32 PM
  Seismic Design and Retrofit of Bridges toa011 6 4,972 08-31-2015, 02:56 PM
Last Post: ibg0203
  METALLIC DAMPERS FOR SEISMIC DESIGN AND RETROFIT OF BRIDGES mahyarov 1 1,983 08-12-2014, 02:10 PM
  Seismic Retrofit Training For Building Contractors & Inspectors arshiakh 1 1,696 02-23-2013, 12:29 PM
Last Post: junaid
  evaluation of seismic retrofit of reinfirced concrete structures , Part II - Experime david-smith 0 1,543 11-16-2012, 08:23 AM
Last Post: david-smith
  SEISMIC PERFORMANCE AND RETROFIT OF MULTI-COLUMN BRIDGE BENTS mahyarov 0 1,374 11-12-2012, 09:10 PM
Last Post: mahyarov
