Civil Engineering Association eBooks Structural Books Concrete Supplementary Cementitious Materials to Enhance Durability of Concrete Bridge Decks
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-25-2012, 04:03 PM
Author: Houston, William N | Size: 3.64 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2005 | pages: 95 | ISBN: -
[Image: 06709107671068290210.png]
Performance objectives for achieving durable bridge deck concrete and the properties of locally available concrete raw materials, particularly supplementary cementitious materials (SCMs) like fly ash, GGBFS and silica fume, vary by geographic region. Because of this variation, the optimum concrete mixture proportions for a given application must be determined by experiment. Since durability-related experimental programs investigating the performance of concrete mixtures are expensive and time-consuming, a methodology for designing and conducting an investigation using statistical experimental design concepts has been developed to efficiently identify the optimum concrete mixture proportions for a specific set of conditions. The approach implemented is based on fractional orthogonal experimental design, which supports modeling for a large number of factors (input variables) based on a minimum number of tests. The Methodology, presented in NCHRP Report 566: "Guidelines for Concrete Mixtures Containing Supplementary Cementitious Materials to Enhance Durability of Bridge Decks," consists of six steps: (1) definition of performance requirements, (2) selection of durable raw materials, (3) construction of an experimental design matrix, (4) testing of concrete mixtures, (5) analysis and empirical modeling to determine the Best Tested and Best Predicted Concretes, and (6) confirmation of predictions and selection of the Best Concrete. This Methodology is flexible and may be applied to a range of performance demands. It was developed to identify optimum contents of SCMs but is also able to select between sources of raw materials. A case study was conducted based on a hypothetical set of service conditions and using concrete raw materials from the Midwest. The performance predictions based on the case study experimental design were verified by confirmation testing. Finally, a computational tool (SEDOC) was developed to support the implementation of this Methodology.
  • david-smith, kowheng, cace-01, oanm2000, Dell_Brett
 Nilupa
Semi Senior Member
Banned
Sri Lanka
User ID: 11056
Threads: 49
Likes: 95 in 26 posts
Given Likes: 4796
11-30-2012, 07:48 AM
Dear david Smith,
Link shoud be corrected as below,
[-] The following 9 users Like Nilupa's post:9 users Like Nilupa's post
  • david-smith, LiviuM, blaze, warlord1, Jackass, zrilek, oanm2000, sodapas, Dell_Brett
  Durability of Reinforced Concrete Structures Dobblo 0 1,497 04-13-2020, 04:38 PM
Last Post: Dobblo
  Performance Criteria for Concrete Durability pezhmankhan 1 2,231 09-03-2019, 05:45 AM
  Concrete Durability: A Practical Guide to the Design of Durable Concrete Structures carolinandra 1 2,036 05-01-2019, 03:06 AM
  Supplementary Cementing Materials in Concrete cace-01 3 2,385 07-03-2018, 04:26 AM
Last Post: axcel
  Marine Concrete Structures - Design, Durability and Performance ir_71 0 1,649 04-25-2017, 04:11 AM
  Mechanics and Physics of Creep, Shrinkage, and Durability of Concrete asim99 2 2,595 04-01-2017, 03:15 PM
Last Post: kmmh76
  Concrete Durability i_kabir 2 2,388 04-01-2017, 03:03 PM
