Civil Engineering Association eBooks Traffic Engineering Environmental Effects in Pavement Mix and Structural Design Systems
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-25-2012, 04:00 PM
Author: Houston, William N | Size: 2.26 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2005 | pages: 298 | ISBN: -
[Image: 83509433791419526067.png]
It is well documented that environmental effects play a significant role in characterizing the material properties, which in turn affect the pavement performance. Studies under the Strategic Highway Research Program (SHRP) were carried out to study the age hardening characteristics of asphalt binders and mixes. As a result of this study, laboratory procedures American Association of State Highway and Transportation Officials, provisional protocols (AASHTO PP1-98 and PP2-99) were developed to study the hardening potential of asphalt binders and mixes. The approaches followed in these procedures are of great value for the ongoing research on pavement aging; however, due to the limited resources and time constraints under the SHRP program, these provisional procedures have certain limitations associated with them. Research study, National Cooperative Highway Research Program (NCHRP) 9-23 was initiated to assess these limitations and if possible, enhance the predictive capabilities of these protocols. Binders and field cores were obtained from LTPP sections and other sites across the United States. Original, laboratory-aged, and field-aged binders were characterized. Based on the findings, an alternate procedure to the AASHTO PP1-98 protocol is suggested and presented. The alternate procedure includes field aging conditions and volumetric properties of the mix. The model developed was calibrated and validated using the data obtained from the field cores. Parametric analysis was performed on the final model to ascertain the practicality of the output. The assessment of the existing PP2-99 test protocol is also presented. Asphalt mix cores aged in the laboratory were tested for complex modulus. These modulus values were then compared to the modulus values of the field cores, the ages of which were known from the construction records. Due to the limited amount of data available, the PP2-99 protocol could not be improved.
  • oanm2000, kowheng, cace-01, Mohammad6299
  [REQUEST] Pavement Design: Materials, Analysis, and Highways cace-01 1 3,237 10-21-2020, 05:55 PM
Last Post: oonan
  Pavement Design and Materials toa011 5 6,350 11-04-2019, 01:21 AM
  Concrete Pavement Design, Construction, and Performance Grunf 14 9,496 10-23-2015, 05:48 PM
Last Post: ibg0203
  Advances in Pavement Design through Full-scale Accelerated Pavement Testing cace-01 4 2,837 01-26-2015, 03:50 AM
Last Post: gulilero
  Contributions of Pavement Structural Layers to Rutting of Hot-Mix Asphalt Pavement mahyarov 0 1,596 10-24-2012, 10:59 AM
Last Post: mahyarov
  Estimating the Effects of Pavement Condition on Vehicle Operating Costs mahyarov 0 1,369 10-23-2012, 06:21 AM
Last Post: mahyarov
  Pavement Design Manual ir_71 2 2,973 10-22-2012, 06:02 AM
Last Post: shadabg
