Civil Engineering Association eBooks Traffic Engineering Top-Down Cracking of Hot-Mix Asphalt Layers: Models for Initiation and Propagation
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-25-2012, 02:39 PM
Author: Roque, Reynaldo | Size: 5.46 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2010 | pages: 286 | ISBN: -
[Image: 76518693496166390639.png]
The research focused on: 1) Finalizing the two primary model components [i.e., a viscoelastic continuum damage (VECD) model for crack initiation and a hot mix asphalt fracture mechanics (HMA-FM) model for crack propagation], involving development and integration of sub-models that are relevant to dominant top-down cracking mechanisms into each model component; 2) Verifying the reasonableness of the two enhanced primary model components (i.e., the VECD-based model and the HMA-FM-based model); and 3) Developing for and integrating with the HMA-FM-based crack propagation model a simplified fracture energy-based crack initiation model to illustrate the potential of a completed system and to help formulate a plan for integrating, calibrating, and validating the two enhanced primary model components. In summary, the work performed clearly indicates that the VECD-based model and the HMA-FM-based model developed and evaluated in this project can form the basis for a top-down cracking model suitable for use in the Mechanistic-Empirical Pavement Design Guide (MEPDG). Furthermore, the component models can form the basis for an improved performance model to predict multiple cracking distresses simultaneously, including top-down cracking, bottom-up cracking, and thermal cracking. The project also identified and recommended research efforts to develop calibrated/validated top-down cracking performance models for use in the MEPDG.
  • kowheng, oanm2000, cace-01, Mohammad6299, Dell_Brett, toa011
  Asphalt Emulsion Technology: Review of Asphalt Emulsion Residue Procedures mahyarov 0 1,714 10-27-2012, 08:35 AM
Last Post: mahyarov
  Contributions of Pavement Structural Layers to Rutting of Hot-Mix Asphalt Pavement mahyarov 0 1,609 10-24-2012, 10:59 AM
Last Post: mahyarov
  Performance-Related Tests of Recycled Aggregates for Use in Unbound Pavement Layers mahyarov 0 1,441 10-23-2012, 08:21 PM
Last Post: mahyarov
  NCHRP - R648 Mixing and Compaction Temperatures of Asphalt Binders in Hot-Mix Asphalt mahyarov 0 1,720 10-23-2012, 04:25 PM
Last Post: mahyarov
  Models for Predicting Reflection Cracking of Hot-Mix Asphalt Overlays mahyarov 0 1,378 10-23-2012, 12:45 PM
Last Post: mahyarov
  Sulfur in asphalt and asphalt mixtures used in paving application david-smith 0 1,698 05-20-2012, 02:36 PM
Last Post: david-smith
