Civil Engineering Association eBooks Geotechnical Engineering Geology APPLIED CLAY MINERALOGY
10-11-2012, 07:32 AM
Author: HAYDN H. MURRAY | Size: 4.6 MB | Format: PDF | Quality: Original preprint | Publisher: Elsevier | Year: 2007 | pages: 189 | ISBN: 0-444-51701-4
[Image: 59240814184823891055.jpg]
Occurrences, Processing and Application of Kaolins, Bentonites, Palygorskite- Sepiolite, and Common Clays
CONTENTS :
Preface
Chapter 1. Introduction
Chapter 2. Structure and Composition of the Clay Minerals and their Physical and Chemical Properties
Chapter 3. Geology and Location of Major Industrial Clay Deposits
Chapter 4. Exploration, Mining, and Processing
Chapter 5. Kaolin Applications
Chapter 6. Bentonite Applications
Chapter 7. Palygorskite and Sepiolite Applications
Chapter 8. Common Clays
Appendix A. Commonly Used Tests and Procedures for Evaluating Kaolin Samples
Appendix B. Common Tests for Evaluation of Ball Clay Samples
Appendix C. Commonly Used Tests to Evaluate Bentonite Samples
Appendix D. Palygorskite–Sepiolite Laboratory Tests
Subject Index
Introduction :
Clays and clay minerals are very important industrial minerals. There are well over one hundred documented industrial applications of clay materials. Clays are utilized in the process industries, in agricultural applications, in engineering and construction applications, in environmental remediations, in geology, and in many other miscellaneous applications. This book is an assimilation of the major and minor uses of clays and clay minerals and explains why an understanding of the structure and physical and chemical attributes of the individual clay minerals are so important. Clay is an abundant raw material which has an amazing variety of uses and properties that are largely dependent on their mineral structure and composition. Other than the clay structure and composition, there are several additional factors which are important in determining the properties and applications of a clay. These are the non-clay mineral composition, the presence of organic material, the type and amount of exchangeable ions and soluble salts, and the texture (Grim, 1950).
[-] The following 5 users Like shadabg's post:5 users Like shadabg's post
  â€¢ kowheng, Dell_Brett, malc, Jackass, zrilek
  Dictionary of Geology & Mineralogy, Second Edition oanm2000 5 3,768 11-01-2012, 09:58 AM
Last Post: david-smith
