Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 1097-10:2002 Tests for mechanical and physical properties of aggregates. Determ
08-20-2012, 02:43 PM
BS EN 1097-10:2002 Tests for mechanical and physical properties of aggregates. Determination of water suction height
Author: Committee B/502/6 | Size: 0.12 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2002 | pages: 11 | ISBN: 0580410153
[Image: 28955776749382290880.jpg]
This European Standard specifies a procedure for determining the water suction height of an aggregate in direct contact with a free water surface.
NOTE Rise of moisture through an aggregate layer under the ground floor may cause moisture problems in the building. If the layer is thicker than the water suction height of the aggregate used, the layer is considered as a water breaking layer.
  • 3fan, st77bel, zrilek, devilmaycry, mahyarov, kowheng, peixoto, lisine, Dell_Brett, Trishu999
  BS EN 1097-2:2010 Tests for mechanical and physical properties of aggregates. Methods ir_71 1 2,092 07-21-2017, 04:39 PM
  BS EN 13242-2002 Aggregates for unbound and hydraulically bound materials for use in st77bel 3 3,330 01-23-2017, 05:52 PM
  BS EN 933-8:2012 Tests for geometrical properties of aggregates. Assessment of fines. mybest 1 2,127 06-05-2014, 02:28 PM
  BS EN 933-10 Tests for geometrical properties of aggregates. Assessment of fines. Gra ir_71 1 2,265 02-24-2014, 05:16 PM
  BS EN 933-3:2012 Tests for geometrical properties of aggregates. Determination of par mybest 1 2,194 10-02-2013, 05:47 AM
  BS EN 1744-1:2009 Tests for chemical properties of aggregates. Chemical analysis ir_71 2 2,572 08-04-2013, 06:18 AM
Last Post: st77bel
  BS EN 13391:2004 Mechanical tests for post-tensioning systems ir_71 1 2,679 03-14-2013, 02:00 PM
