Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Wind-moment Design of Low Rise Frames-Salter P R, Couchman G H, Anderson D
 ahphuah
Junior Member
User ID: 1592
Threads: 11
Likes: 149 in 11 posts
Given Likes: 28
09-16-2009, 02:50 PM
This publication presents procedures for the design of wind-moment frames in accordance with BS 5950-1. In this method of design, the frame is made statically determinate by treating the connections as pinned under vertical loads and fixed under horizontal loads (with certain assumed points of zero moment). The publication gives design procedures for frames that are braced in the minor axis direction and for frames that do not have bracing in either principal direction. The limitations of the method, which differ slightly for these two cases, are explained. In particular, it should be noted that the method is only recommended for low-rise frames up to four storeys high.
[Image: 1-85942-097-4.jpg]
Anyone have this book to share?
[-] The following 2 users Like ahphuah's post:2 users Like ahphuah's post
  • levanduy, levanduy
 tacky2010
User ID: 13415
Threads: 2
Likes: 87 in 13 posts
Given Likes: 0
02-24-2010, 07:45 AM
Reply: Wind-moment Design of Low Rise Frames-Salter P R, Couchman G H, Anderson D
[-] The following 8 users Like tacky2010's post:8 users Like tacky2010's post
  • lucky_b2me, robertsas, rendel_©, kowheng, simanta, Ultra Zone, oanm2000, mowafi3m
  [REQUEST] Steel TIPS: Design of RBS Connections for Special Moment Frames (2006) Administrator 1 2,267 05-13-2017, 08:58 AM
Last Post: miquan
  [REQUEST] The Design of Continuity Plate Welds in Special Moment Frames NINJAKO 0 1,318 11-19-2016, 08:54 PM
Last Post: NINJAKO
  [REQUEST] Surveying: Theory and Practice by James Anderson, Edward Mikhail ervikas34 0 1,261 02-15-2014, 03:30 PM
Last Post: ervikas34
  [REQUEST] Environmental Wind Engineering and Design of Wind Energy Structures apocalipse 2 1,995 01-03-2014, 08:35 PM
Last Post: Dell_Brett
  [REQUEST] On the Design of Eccentrically Braced Frames apocalipse 1 1,682 07-23-2012, 07:05 AM
Last Post: shadabg
  [REQUEST] Plastic Design of Frames psa_1987 2 2,350 06-06-2012, 04:59 AM
Last Post: adshrt
  [REQUEST] Plastic Design of Low Rise Frames leetse 0 1,286 06-03-2012, 08:32 PM
Last Post: leetse
