Civil Engineering Association eBooks Structural Books Concrete Concrete Behaviour in Multiaxial Compression
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
05-24-2012, 09:42 AM
Concrete Behaviour in Multiaxial Compression: Experimental Research
Author: Erik Van Geel | Size: 14.1 MB | Format: PDF | Quality: Scanner | Publisher: Technische Universiteit Eindhoven | Year: 1998 | pages: 169 | ISBN: 9068145487, 978-9068145489
[Image: 91381150740205686027.jpg]
In a large number of concrete structures and structural elements multiaxial compressive stress states occur. As is generally known, these stress states in general have an advantageous effect on the behaviour of the material, compared to the behaviour under uniaxial loading: the load bearing capacity increases and larger deformations are allowable. Unfortunately, this effect has not yet been implemented in the building codes, because there are too many unknowns to describe it in a useful quantitative manner. Therefore insight in the behaviour of concrete under this type of loading is important with respect to safety and deformational capacity of several kinds of concrete structures. At Eindhoven University of Technology (EUT) a research project was started in the early eighties to gain more insight in the failure behaviour of concrete in multiaxial compression. The research described in this thesis is to be regarded as a continuation of the work done earlier at EUT. It deals with several aspects of concrete behaviour in multiaxial compression that were not investigated before or from a different point of view, and intends to answer some remaining questions on the subject.
Direct link
or
[-] The following 11 users Like lisine's post:11 users Like lisine's post
  • Jackass, ynopum, malc, david-smith, kowheng, miquan, zrilek, gulilero, stash, mgdario, Dell_Brett
  Time-Dependent Behaviour of Concrete Structures ir_71 9 9,383 01-13-2025, 08:17 AM
Last Post: concreteok
  Behaviour Of Reinforced Concrete Flat Slabs mowafi3m 3 3,971 07-19-2018, 12:38 PM
Last Post: febo927
  Creep Behaviour in Cracked Sections of Fibre Reinforced Concrete: TAFATNEB 1 1,699 02-06-2017, 06:22 AM
  FIB 46: Fire design of concrete structures - structural behaviour and assessment oscargon 1 2,030 04-03-2014, 07:50 AM
Last Post: Mohammad6299
  COMPRESSION TESTING OF CONCRETE: CYLINDERS VS. CUBES mowafi3m 0 1,760 01-04-2011, 07:26 PM
Last Post: mowafi3m
