Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Ductile Seismic Design of Steel-Concrete Composite Structures
[Request] Ductile Seismic Design of Steel-Concrete Composite Structures
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
05-01-2012, 11:28 PM (This post was last modified: 05-01-2012, 11:50 PM by mybest.)
Srour Nofal
[Image: 47587687049714186926.jpg]
Publisher LAP Lambert Academic Publishing, 2012
ISBN 3848443325, 9783848443321
Length 248 pages
In order to allow the formation of the greatest number of plastic hinges and to dissipate as much as possible seismic energy of moment-resisting frames, dissipative zones should be mainly located in plastic hinges in the beams or in the beam-column joints, but not in the columns except at the base of the frame. It is clear that this design method strongly depends on actual mechanical properties of materials. The possibility that the actual yield strength of steel is higher than the nominal yield strength in dissipative zones should be taken into account by a material overstrength factor for the design of non-dissipative zones. In spite of the fact that this point is essential in seismic design, the value to be given to this overstrength factor varies in the provisions of different standards. Moreover, these standards don't provide adequate limitations on mechanical properties for steel products even if it should be directly related to the overstrength factor chosen. For these reasons, this work aimed to define suitable harmonised rules and recommendations for production standards and structural regulations for steel-concrete composite structures located at earthquake-prone areas.
  [REQUEST] Seismic Design of Precast/Prestressed Concrete Structures aslam 1 2,449 06-06-2019, 03:45 PM
Last Post: temp1366
  [REQUEST] ECCS - Design of Cold-formed Steel Structures:Eurocode 3 agelos100 1 2,205 09-30-2017, 12:58 PM
Last Post: mike85
  [REQUEST] Instructor's solution manual for Ductile Design of Steel Structures, 2nd Ed Saze808 1 2,692 11-08-2016, 11:08 AM
Last Post: vsuarez
  [REQUEST] CS TR55 - Design Guidance for Strengthening Concrete Structures using Fibre Composite AlmostThere 2 2,335 02-16-2016, 07:55 AM
Last Post: AlmostThere
  [REQUEST] Design of cold-formed steel structures (to AS/NZS 4600:2005) ErnestoIII 0 1,569 12-04-2014, 11:06 AM
Last Post: ErnestoIII
  [REQUEST] Assessment of EC8 Provisions for Seismic Design Steel Structures apocalipse 0 1,401 09-12-2014, 05:06 PM
Last Post: apocalipse
  [REQUEST] Design of Steel-Concrete Composite Bridges to Eurocodes Kurucz 0 1,390 07-28-2014, 07:44 AM
Last Post: Kurucz
