Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Plastic Design of Steel Plate Shear Walls: Introduction to Performance Based Seismic
[Request] Plastic Design of Steel Plate Shear Walls: Introduction to Performance Based Seismic
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
05-01-2012, 10:20 PM (This post was last modified: 05-01-2012, 11:35 PM by mybest.)
Introduction to Performance Based Seismic Design of Steel Plate Shear Walls
Farooq Adam
[Image: 29303358968653203253.jpg]
Publisher VDM Verlag, 2010
ISBN 3639296877, 9783639296877
Length 180 pages
The unstiffened steel plate shear wall (SPSW) system has emerged as a promising lateral load resisting system in recent years. However, seismic code provisions for these systems are still based on elastic force-based design methodologies. Considering the ever-increasing demands of efficient and reliable design procedures, a shift towards performance-based seismic design (PBSD) procedure is proposed in this work. The proposed PBSD procedure for SPSW systems is based on a target inelastic drift and pre-selected yield mechanism. This design procedure is simple, yet it aims at an advanced design criterion. The proposed procedure is tested on a four-story test building with different steel panel aspect ratios for different target drifts under selected strong motion scenarios. The designs are checked under the selected ground motion scenarios through nonlinear response-history analyses. The actual inelastic drift demands are found to be close to the selected target drifts. In addition, the displacement profiles at peak responses are also compared with the selected yield mechanism.
[-] The following 2 users Like david-smith's post:2 users Like david-smith's post
  • awgawhtoo80, civilgr
  [REQUEST] ACI SP-240 Performance-Based Design of Concrete Buildings for Wind Loads ebcivilea 2 2,882 06-20-2019, 09:20 AM
Last Post: concreteok
  [REQUEST] Performance-Based Seismic Evaluation of Ping An International Finance Center ASEC 1 1,819 08-14-2017, 09:21 AM
Last Post: pezhmankhan
  [REQUEST] Non-Linear Time History Analysis for the Performance Based Design of Shanghai Tower ASEC 1 1,876 08-13-2017, 01:14 PM
  [REQUEST] Cyclic Performance of Concrete-Backed Stone Masonry Walls abouferass88 1 1,635 04-18-2016, 04:29 PM
Last Post: ssobhan
  [REQUEST] Assessment of EC8 Provisions for Seismic Design Steel Structures apocalipse 0 1,461 09-12-2014, 05:06 PM
Last Post: apocalipse
  [REQUEST] Video of Seismic Performance of Existing Concrete Buildings RyanRS 0 1,444 07-16-2014, 10:07 AM
Last Post: RyanRS
  [REQUEST] A Model Code for the Displacement-Based Seismic Design of Structures Editors: G.M. Ca dynaquake 3 3,421 07-09-2014, 10:44 AM
Last Post: RyanRS
