Civil Engineering Association eBooks Bad Posts (eBooks) Download structural book and others
Thread Closed
 zego2000
User ID: 1459
Threads: 4
Likes: 219 in 30 posts
Given Likes: 443
09-05-2009, 08:29 PM (This post was last modified: 12-08-2011, 10:31 PM by usman.)
instead to uploading links to different books one by one
here a link to a good collection of books
1-theory of structures
Introduction. Scope. Types of structures and supports. Types of loads. Conditions of static stability. Calculations of reactions. Definition of internal forces (normal forces, shear forces, bending moments and twisting moments). Internal forces in the horizontal beams (cantilevers, simple beams, overhanging beams, compound beams). Differential relations between loads and internal forces. Internal forces in inclined beams. Internal forces in simple, hinged, compound, and arched frames. Analytical and graphical methods for finding the internal forces in simple ,compound ,and subdivided trusses and trussed beams, Influence lines for statically determinate structures. Properties of plane areas: – principal axes and principal moments of inertia, Mohr’s circle. Distribution of normal stresses: – normal stresses due to single and double bending in symmetric and non-symmetrical sections, eccentric normal forces, core theory. Distribution of shear stresses: – direct shear, shear in bending, line sections, shear flow, shear center, non-symmetrical sections. Torsion:- applications on power transmission shafts. Plane stresses and strains:- principal stresses and similarity between stresses and strains, strain rosette. Deflection of beams:- method of double integration, method of elastic loads, deflection of beams with variable cross sections. Buckling of compression members (columns):- critical loads for columns under centric loads, compression members under eccentric loads and lateral loads Statics of structures. Internal forces in plane beams. Internal forces in trusses. Normal and shear stresses distribution. Concrete foundations for electrical equipments and the effect of vibrations,Analysis of statically indeterminate structures by the method of superposition, beams with variable cross sections and beams on elastic supports . Analysis of statically indeterminate structures by the method of three moment equation. Maximum diagrams of shear forces, bending moments for statically indeterminate beams . Elastic strain energy . Theory of virtual work:– calculation of deformations in statically determinate structures due to loads and temperature changes. Analysis of statically indeterminate structures by the method of virtual work:- beams, frames, arches and trussed beams . Effect of yielding of supports and temperature changes Analysis of statically indeterminate structures by the method of moment distribution:– stiffness coefficients, distribution and carry over factors, fixed end moments ,structures without lateral sway, method of successive carry over, structures with lateral sway, elastic supports, yielding of supports and temperature changes . Influence lines for statically indeterminate structures using the different methods of analysis . Introduction to stiffness method for structural analysis, Study of the principles of statics for structures. Introduction to principle theories of structural systems .Concepts of structural behavior for building systems(reactions, equilibrium, stability, stiffness). Static analysis of forces. Study of internal and external forces and analytical solutions for rigid stable bodies. Diagrams of internal forces (bending moments, shear forces, normal forces). Methods of calculating structural deformations and deflection of statically determinate beams . Introduction to statically indeterminate structures, the analysis of statically indeterminate structures by the method of superposition and the method of three moment equation . Analysis of plane internal stresses (types of stresses, properties of areas, distribution of normal stresses, shear stresses in bending and torsion ). Buckling of columns
2-structural engineering books
Shear forces and bending moments for beams ,frames. Internal forces in trusses . Tests and measurements of mechanical properties of materials (simple tensile test, compression test, shear test, torsion test, bending test). Impact and hardness tests . Rotating beam tests. Measurement of strains. Construction materials – Design consideration and criteria – Design loads – Allowable stresses – Design of tension members – Stability of structures against lateral loads – Stability of multistory buildings – Buckling of columns – Design of axially loaded compression members – Design of laterally supported beams – Bolted and welded connections – Design of bracing systems – Column design by charts – Beam design by charts – Castellated beams – Design of floor decking sheets Reinforced Concrete: Fundamental of Reinforced concrete structural design – Analysis and design of sections subjected to bending – Load distribution – Details of beam reinforced – Solid slabs – Columns stairs – Frames – Ribbed slabs – Slabs with beams – Joints of precast reinforced concrete element. Soil Mechanics and Foundation: Properties of soils – Soil classification – Soil compaction – Stress distribution in soil – Consolidation theory – Lateral earth pressure – Shallow foundation – Deep foundation – Retaining walls –soil investigation
3-strcutural analysis
Study of matrices, stiffness and flexibility for structural analysis, matrix structural analysis ,stiffness matrices for different structural members (plane and space),overall stiffness equation for the structure, boundary conditions, calculation of internal forces in the members, effect of yielding of supports and temperature changes, Influence lines. Grid systems. Use of computer for analyzing structures by the stiffness method . Use of software packages for structural analysis .Introduction to dynamics of structures, Direct and indirect aspects, Indirect models (displacement models) Influence line diagrams for deflection, Influence line diagrams for stress resultant, Scale factors, Practical applications of the indirect method, Experimental procedure in the indirect method, Direct method of model analysis, Applications, Influence surfaces for deformations and internal forces, Approximate methods for analysis of statically indeterminate structures, Reasons for performing approximate analysis, Assumptions, Approximate analysis for industrial buildings, Approximate analysis for double diagonals trusses, Continuous beams under gravity loads, Building frames subjected to lateral loads, Portal frame method, Cantilever method, Vierendeel trusses, Approximate methods of shell analysis, Choice of method and inaccuracies of approximate methods. Plastic analysis of beams and frames, Definitions, Material behaviour, Assumptions, Theories of plastic analysis, Applications on beams and frames, Effect of normal forces, Analysis of plane frames, Grillages and space trusses using the stiffness method, Degrees of freedom and sign convention, Element stiffness matrix in element local axes, Transformation matrix for forces and displacements in global axes, Equilibrium equations in global axes, Internal forces in members of the structure, Influence of temperature change and settlement of supports, Effect of axial force on the stiffness of structures [P-delta effect], Stability functions and equations of stability, Buckling of trusses and frames, Applications, Structural dynamicS, Definitions, Classification of structural systems, Free vibration of SDOF systems, Undamped vibration, Damped vibration, Forced vibration of SDOF systems, Response to constant and harmonic forces, Response to general type of forces (using duhamel integration).
4-concrete structurs
Design of rectangular and square slabs under uniform loads and line loads, Design of hollow block slabs, One way and two slabs, Design of panelled beams, Design of beams under torsional moment and taking into consideration the effect of shear stresses, Design of stairs, Design of columns under biaxial moments, Design of short and long columns under centric and eccentric loads. Design of R.C. shallow foundations, Design of simple and continuous girders, Design of statically determinate and statically indeterminate frames and design of hinges. Design of trusses, Vierendeel girders, Arch slabs, Arch girders, Design of saw tooth slab and girder types, Details of joints in R.C. structures, Structural systems of buildings (wall bearing, skeleton). Physical and mechanical properties of concrete and reinforcing steel. Loads on buildings, Load distribution on beams. Behaviour and design of reinforced concrete beams, (simple, continuous and cantilever beams). Behaviour and design of axially loaded short columns. Study structural systems of slabs (solid, hollow block, ribbed, flat slab and panelled beams). Behaviour and design of reinforced concrete solid slabs (one and two way). Structural systems of stairs. Structural systems of reinforced concrete halls (frames, domes, cones, surfaces of revolution, folded plates, shells, ... etc.). Study of physical and mechanical properties of concrete and steel reinforcement, Study of structural systems, Statical systems of floor elements and load distribution on different supporting elements, Experimental behaviour of reinforced concrete elements under flexure, Design of short columns under axial and eccentric loads, Design of reinforced concrete beams and statically determinate frames under bending moments and normal and shearing forces using the limit state design method, Study of bond between concrete and steel, The development length of reinforcement, Details of reinforcement of beams and statically determinate frames, Study of serviceability limit states (deflection and cracking) and design of reinforced concrete elements using the working stress design method.
and other topics
the link
enjoy
Or, sometimes the password should be visible when you open the file in WinRAR.
[-] The following 37 users Like zego2000's post:37 users Like zego2000's post
  • neverdie, neverdie, ajmf77, ajmf77, aslam, aslam, cristi, cristi, zrilek, zrilek, surajdas, surajdas, libe, libe, Nilupa, imran23, livanhg, geotecnico, kerenski_t, ladjin, ska51, dinu69in, u4406014, rohailiyaz, exengexeng, kaungthant, Chicosi34, chenamoy, homebysea, jbahari, str_design, berx1211, saiwal, dquan373, malc, techno, youceftli
 tuntnguyen
User ID: 17155
Threads: 0
Likes: 6 in 1 posts
Given Likes: 5
03-25-2010, 08:47 PM (This post was last modified: 03-26-2010, 01:36 AM by BennyP.)
Filename: Post-Tensioning.pdf
Filesize: 765 kB
Upload-Date: 26/01/2010
Download-Link:
Filename: Professional Property Development.pdf
Filesize: 10 MB
Download-Link:
Filename: Reinforced concrete analysis and design.pdf
Filesize: 13 MB
Download-Link:
Filename: Residential_Structural_Design_Guide.pdf
Filesize: 3 MB
Download-Link:
Filename: Ritual House - Drawing on Nature's Rhythms for Architecture and Urban Design - 1-59726-050-9.pdf
Filesize: 5 MB
Download-Link:
Filename: Sadd - Elasticity theory applications and numerics [butterworth heinemann 2004] 4AH.pdf
Filesize: 9 MB
Download-Link:
Filename: Sample Bidding Documents for Simple Works.pdf
Filesize: 830 kB
Download-Link:
Filename: Scaling_of_Structural_Strength.pdf
Filesize: 27 MB
Download-Link:
Filename: Simplified_bridge EurocodesV01.pdf
Filesize: 880 kB
Download-Link:
Filename: Soil engineering - testing, design, and remediation.pdf
Filesize: 3 MB
Download-Link:
Filename: Soil_Mechanics___Foundations.pdf
Filesize: 1 MB
Download-Link:
Filename: Solar Power in Building Design.pdf
Filesize: 4 MB
Download-Link:
Filename: Steel designers manual 5th edition.pdf
Filesize: 43 MB
Download-Link:
Filename: Stiffener Design for Beam-to-Column Connections.rar
Filesize: 371 kB
Download-Link:
Filename: Structural Aspects of Building Conservation - 0 7506 5733 2.pdf
Filesize: 7 MB
Download-Link:
Filename: TONG, L. (2002). 3D Fibre Reinforced Polymer Composites.rar
Filesize: 4 MB
Download-Link:
Filename: Teexas - Hydraulic Design Manual.pdf
Filesize: 5 MB
Download-Link:
Filename: The Civil_Engineering_Handbook-2Ed.pdf
Filesize: 38 MB
Download-Link:
Filename: The_Finite_Element_Method.pdf
Filesize: 10 MB
Download-Link:
Filename: Time-dependent problems with the boundary integral equation.pdf
Filesize: 254 kB
Download-Link:
Filename: Transportation Systems Planning Methods and Applications.rar
Filesize: 10 MB
Download-Link:
Filename: Vibration Simulation using MATLAB and ANSYS.rar
Filesize: 7 MB
Download-Link:
Filename: Vibration and Shock Handbook.rar
Filesize: 131 MB
Download-Link:
Filename: Vibrations Fundamentals and Practice.rar
Filesize: 24 MB
Download-Link:
Filename: Vol 1 Non-Linear Finite Element Analysis Of Solids And Structures Essentials.pdf
Filesize: 12 MB
Download-Link:
Filename: WATSON, D. G. M. (1998). Practical Ship Design.zip
Filesize: 20 MB
Download-Link:
Filename: WU, Y.-S. (2001). Practical Design of Ships and Other Floating S.rar
Filesize: 13 MB
Download-Link:
Filename: Welded Design - Theory and Practice.rar
Filesize: 3 MB
Download-Link:
Filename: Welded steel.pdf
Filesize: 7 MB
Download-Link:
Filename: Welding Metallurgy (Second Edition).rar
Filesize: 48 kB
Download-Link:
Filename: Wind Loading of Structures.zip
Filesize: 14 MB
Download-Link:
Filename: YUN, L. (2000). Theory and Design of Air Cushion Craft.rar
Filesize: 45 MB
Download-Link:
Filename: ZIENKIEWICZ, O. C. (2000). The Finite Element Method (5th ed.).).rar
Filesize: 16 MB
Download-Link:
Filename: Zienkiewicz's Finite Element Book.zip
Filesize: 57 MB
Download-Link:
Filename: strength of materials.pdf
Filesize: 32 MB
Download-Link:
Filename: stress analysis of why branch.pdf
Filesize: 12 MB
Download-Link:
[-] The following 6 users Like tuntnguyen's post:6 users Like tuntnguyen's post
  • jferrer, nhim4mat2006, prapruk, darkthrone, jbahari, Struc-Con
