Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Regarding Soft Storey Effect on Hi-Rise Building
[Request] Regarding Soft Storey Effect on Hi-Rise Building
 kirankumarklk
User ID: 29935
Threads: 76
Likes: 960 in 135 posts
Given Likes: 280
02-14-2012, 12:36 PM
Hi All.
Please anybody Share Technical Papers or Journals On Soft Storey Effect And Design Approach on Hi-Rise buildings With Software's.
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
02-14-2012, 02:00 PM
Soft storey effect is related to stiffness irregularities. depending upon stiffness of particular floor you may have soft story or extreme soft storey (refer your seismic code).
You may expect soft - storey in following condition:
(1) At ground floor with parking (no walls) and walls with considerable stiffness at upper floors.
(2) At upper recess floor with no walls and walls with considerable stiffness at other floors.
(3) At floor where there is sudden reduction in overall stiffness of floor (columns/shear walls/brick walls) as compared to other floors.
Approximate design approach:
(1) Soft-storey elements (column, shear wall, floor beams above and below floor) may be designed for 2.5 times worst load. (may be other value for other country code). If you have no cladding walls or walls with lesser stiffness (i.e. less thickness or with large opening) then you may reduce this multiplying factor by appropriate value.
Exact design approach:
You may model cladding wall as bracing (of representative size, search forum) along with other structural element and perform dynamic analysis and design structural members for the worst load.
  [REQUEST] NON SWAY AND SWAY METHODS FOR DESIGN OF MULTI-STOREY RC BUILDING: ANALYSIS AND DESIGN alilo 2 2,028 03-27-2013, 03:14 AM
Last Post: ASEC
  [REQUEST] Progressive collapse analysis of high rise building hmwere 2 2,259 02-08-2013, 08:39 AM
