Civil Engineering Association eBooks Codes, Manual & Handbook ASME SECTION VIII
ASME SECTION VIII
 jamildear4u
User ID: 5529
Threads: 87
Likes: 1,063 in 108 posts
Given Likes: 145
01-17-2012, 06:22 PM (This post was last modified: 01-17-2012, 06:38 PM by jamildear4u.)
2010 ASME BPVC, Section VIII, Division 1: Rules for Construction of Pressure Vessels, Includes 2011 Addenda
Author: American Society of Mechanical Engineers | Size: 12.1 MB | Format: PDF | Quality: Original preprint | Year: 2011 | pages: 806
[Image: 15108196885644391893.png]
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures exceeding 15 psig. Such pressure vessels may be fired or unfired. Specific requirements apply to several classes of material used in pressure vessel construction, and also to fabrication methods such as welding, forging and brazing. It contains mandatory and non-mandatory appendices detailing supplementary design criteria, nondestructive examination and inspection acceptance standards. Rules pertaining to the use of the U, UM and UV Code symbol stamps are also included.
2010 ASME BPVC, Section VIII, Division 2: Alternative Rules, Includes 2011 Addenda
Author: American Society of Mechanical Engineers | Size: 10.6 MB | Format: PDF | Quality: Original preprint | Year: 2011 | pages: 778
[Image: 21595809518816860609.png]
These rules provide an alternative to the minimum requirements for pressure vessels under Division 1 rules. In comparison the Division 1, Division 2 requirements on materials, design, and nondestructive examination are more rigorous; however, higher design stress intensify values are permitted. Division 2 rules cover only vessels to be installed in a fixed location for a specific service where operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications. These rules may also apply to human occupancy pressure vessels typically in the diving industry.
2010 ASME BPVC, Section VIII, Division 3: Alternative Rules for Construction of High Pressure Vessels
Author: American Society of Mechanical Engineers | Size: 4.8 MB | Format: PDF | Quality: Original preprint | Year: 2011 | pages: 384
[Image: 10007764640936666086.png]
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures generally above 10,000 psi. Such vessels may be fired or unfired. This pressure may be obtained from an external source, a process reaction, by the application of heat from a direct or indirect source, or any combination thereof. Division 3 rules cover vessels intended for a specific service and installed in a fixed location or relocated from work site to work site between pressurizations. The operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications. Division 3 does not establish maximum pressure limits for either Section VIII, Divisions 1 or 2, nor minimum pressure limits for this Division. Rules pertaining to the use of the UV3 Code symbol stamps are also included.
[-] The following 14 users Like jamildear4u's post:14 users Like jamildear4u's post
  • ssobhan, NBZ1400, dovsky, kowheng, hcardenas, malc, mahyarov, slowet, duazo2009, GMianG, Jackass, foxxx2010, ilya_kon, oanm2000
 hodzicemir
Bosnia and Herzegovina
User ID: 36740
Threads: 15
Likes: 783 in 83 posts
Given Likes: 467
09-28-2015, 07:53 AM
ASME BPVC 2013 - Section VIII, Division 3: Alternative Rules for Construction of High Pressure Vessels
Author(s)/Editor(s): ASME | Size: 17 MB | Format: PDF | Quality: Unspecified | pages: 418
This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures generally above 10,000 psi. Such vessels may be fired or unfired. This pressure may be obtained from an external source, a process reaction, by the application of heat from a direct or indirect source, or any combination thereof. Division 3 rules cover vessels intended for a specific service and installed in a fixed location or relocated from work site to work site between pressurizations. The operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications. Division 3 does not establish maximum pressure limits for either Section VIII, Divisions 1 or 2, nor minimum pressure limits for this Division. Rules pertaining to the use of the UV3 ASME Product Certification Marks are also included.
Careful application of this Section will help users to comply with applicable regulations within their jurisdictions, while achieving the operational, cost and safety benefits to be gained from the many industry best-practices detailed within these volumes.
[-] The following 3 users Like hodzicemir's post:3 users Like hodzicemir's post
  • PinkPant, Dell_Brett, oanm2000
 PinkPant
Turkey
User ID: 25448
Threads: 66
Likes: 4,006 in 374 posts
Given Likes: 10354
09-28-2015, 01:38 PM
PinkPant
[-] The following 3 users Like PinkPant's post:3 users Like PinkPant's post
  • Dell_Brett, Jackass, oanm2000
  ASME BPVC Section VI - Recommended Rules for the Care and Operation of Heating Boiler hodzicemir 1 1,845 09-28-2015, 01:58 PM
Last Post: PinkPant
  ASME SECTION VII 2013 - Recommended Guidelines for the Care of Power Boilers by ASME hodzicemir 1 1,894 09-28-2015, 01:44 PM
Last Post: PinkPant
  ASME BPVC 2013 - Section VIII, Division 2: Alternative Rules hodzicemir 1 1,827 09-28-2015, 01:35 PM
Last Post: PinkPant
  2010 ASME BPVC Section IX welding code duazo2009 3 4,024 04-28-2015, 08:48 AM
Last Post: PinkPant
