Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13171:2008 Thermal insulating products for buildings - Factory made wood fibre
12-26-2011, 08:51 AM
BS EN 13171:2008 Thermal insulating products for buildings - Factory made wood fibre (WF) products - Specification
Author: CEN/TC 88 | Size: 0.33 MB | Format: PDF | Publisher: CEN | Year: 2008 | pages: 40
[Image: 82789454464205894480.jpg]
This European Standard specifies the requirements for factory made wood fibre products, with or without facings or coatings, which are used for the thermal insulation of buildings1. The products are manufactured in the form of rolls, batts, felts, boards or slabs.
This European Standard specifies product characteristics and includes procedures for testing, evaluation of conformity, marking and labelling.
Products covered by this European Standard are also used in prefabricated thermal insulation systems and composite panels; the performance of systems incorporating these products is not covered.
This European Standard does not specify the required level of a given property to be achieved by a product to demonstrate fitness for purpose in a particular application. The classes and levels required for a given application are to be found in regulations or non-conflicting standards.
Products with a declared thermal resistance lower than 0,50 m2⋅K/W or a declared thermal conductivity greater than 0,070 W/(m⋅K) at 10 °C are not covered by this European Standard.
This European Standard does not cover in situ insulation products and products intended to be used for the insulation of building equipment and industrial installations.
  • Dell_Brett, blaze, kowheng, vpmohammed, Jackass, peixoto
  ISO 14127: Carbon-fibre-reinforced composites Determination of the resin, fibre and v poolmand 0 2,540 11-16-2024, 01:08 PM
  BS 7543:2003 Guide to durability of buildings and building elements, products and ir_71 2 2,806 03-13-2018, 11:22 AM
  BS EN 1170-8:2008 - Test method for glass-fibre reinforced cement. yakwetu 1 1,799 04-27-2016, 04:18 PM
Last Post: abualamal
  BS EN 1170-5:Precast concrete products. Test method for glass-fibre reinforced cement yakwetu 2 2,221 04-27-2016, 02:02 PM
  BS EN 752:2008 Drain and sewer systems outside buildings ir_71 4 4,889 08-19-2015, 04:59 AM
Last Post: concreteok
  BS EN 13167:2008 Thermal insulation products for buildings - Factory made cellular gl ir_71 1 2,194 02-26-2013, 08:56 AM
Last Post: arshiakh
  BS 5422:2009 Method for specifying thermal insulating materials mybest 2 2,557 02-26-2013, 06:54 AM
Last Post: arshiakh
