Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Landslides: Causes, Types and Effects
 portal61
Indonesia
User ID: 12856
Threads: 67
Likes: 855 in 90 posts
Given Likes: 223
12-22-2011, 11:47 AM
Author: Ernest D. Werner (editor) and Hugh P. Friedman (editor) | Size: 19.3 MB | Format: PDF | Publisher: Nova Science | Year: 2010 | pages: 417 | ISBN: 1607412586
[Image: 48738445830094170390.jpg]
A landslide is a geological phenomenon which includes a wide range of ground movement, such as rock falls, deep failure of slopes and shallow debris flows, which can occur in offshore, coastal and onshore environments. Although the action of gravity is the primary driving force for a landslide to occur, there are other contributing factors affecting the original slope stability. Typically, pre-conditional factors build up specific sub-surface conditions that make the area/slope prone to failure, whereas the actual landslide often requires a trigger before being released. This book discusses such triggers, as well as their outcomes.
Research studies of landslides that have occurred in various geographical settings are also among the topics examined in this book, as well as an analysis of the factors that caused them.
Contents
1. Mass Movements in Adriatic Central Italy: Activation and Evolutive Control Factors.
2. Causes and Effects of Landslides in the Monterrey Metropolitan Area, NE Mexico.
3. Mitigation of Large Landslides and Debris Flows in Slovenia.
4. Geomatic Methods for Punctual and Areal Control of Surface Changes Due to Landslide Phenomena.
5. Using Largest Seismically Induced Landslides for Estimating Earthquake Magnitudes and Topography Changes.
6. Recognition of Likely Large-Scale Landslip Failure Surfaces through Geotechnical Core Logging Methods.
7. Multi-scale Analysis for Estimating Strong Ground Motion and Structure Responses.
8. Prediction of the Seismic Displacement of Landslides Using a Multi-block Model.
9. Faults Activity, Landslides and Fluvial Catchments Triggered by the 28 December 1908 Messina Strait Earthquake (Italy).
10. Special Problems in Landslide Modelling: Mathematical and Computational Methods.
Made By CivilEA Post-Generator ver 2.1.2
[-] The following 17 users Like portal61's post:17 users Like portal61's post
  • lisine, cace-01, 3fan, Evandrojr, Dell_Brett, pedzaquino, Jackass, kowheng, nhim4mat2006, peymanlord, cigutierrezg, JJ-HH, Sumatra, Ivan_1980, hamzageo, oanm2000, gibran
  Landslides: Types, Mechanisms and Modeling cace-01 2 2,598 08-20-2019, 09:53 PM
Last Post: Nita1391
  Pile Types Selection - CIRIA Report PG1 gianniorlati 0 1,707 06-04-2019, 04:04 PM
Last Post: gianniorlati
  Introduction to the Physics of Landslides Notter 4 2,761 10-31-2014, 05:13 PM
Last Post: r3be1
  Landslides in Sensitive Clays: From Geosciences to Risk Management cace-01 1 1,770 08-26-2014, 06:00 PM
Last Post: r3be1
  Landslides And Engineered Slopes. From The Past To The Future kevin8107 4 3,929 06-16-2014, 05:33 AM
Last Post: Mohammad6299
  The Landslide Handbook -A guide to understanding Landslides ELAHI1979 4 3,523 10-01-2012, 11:27 AM
Last Post: shadabg
  Landslides in Practice - Derek Cornforth aleph177 2 2,949 09-23-2011, 11:52 AM
Last Post: 3fan
