Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 10305 part 1 to part 6- Steel tubes for precision applications
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
11-28-2011, 06:48 AM (This post was last modified: 11-28-2011, 10:02 AM by kowheng.)
Size: 5 MB | Format: PDF | Publisher: BSI
BS EN 10305 Steel tubes for precision applications. Technical delivery conditions, consists of the following parts:
Part 1: Seamless cold drawn tubes
Part 2: Welded cold drawn tubes
Part 3: Welded cold sized tubes
Part 4: Seamless cold drawn tubes for hydraulic and pneumatic power systems
Part 5: Welded cold sized square and rectangular tubes
Part 6: Welded cold drawn tubes for hydraulic and pneumatic power system
BS EN 10305-1 is the standard that specifies the technical delivery conditions for seamless cold drawn steel tubes of circular cross section for precision applications with specified outside diameter D ≤ 380 mm.
Part 1 of BS EN 10305 can also be applied to other types of cross sections. Tubes according to this document are characterized by having precisely defined tolerances on dimensions and a specified maximum surface roughness. Typical fields of application are in the automotive , furniture and general engineering industries.
BS EN 10305-2 is the standards that specifies the technical delivery conditions for welded cold drawn steel tubes of circular cross section for precision applications with specified outside diameter D ≤ 150 mm.
Part 2 of BS EN 10305 may also be applied to other types of cross section. Tubes according to this document are characterized by having precisely defined tolerances on dimensions and a specified maximum surface roughness. Typical fields of application are in the automotive , furniture and general engineering industries.
BS EN 10305-3 is the standard that specifies the technical delivery conditions for welded cold sized steel tubes of circular cross section for precision applications with specified outside diameter D ≤ 193,7 mm.
Part 3 of BS EN 10305 may also be applied to other types (excluding square and rectangular) of cross section. Tubes according to this document are characterized by having precisely defined tolerances on dimensions and a specified maximum surface roughness. Typical fields of application are in the vehicle , furniture and general engineering industries.
BS EN 10305-5 is the standard that specifies the technical delivery conditions for welded cold sized steel tubes of square and rectangular cross section for precision applications.
Tubes according to BS EN 10305 are characterised by having precisely defined tolerances on dimension and a specified maximum surface roughness. Typical fields of application are in the automotive, furniture and general engineering industries.
[-] The following 11 users Like mybest's post:11 users Like mybest's post
  • Grunf, Dell_Brett, kowheng, vvvv, warbeast, lisine, peixoto, Jackass, ir_71, NBZ1400, toa011
  ISO/TR 22762-7: Elastomeric seismic-protection isolators Part 7: Relationship of the poolmand 0 2,611 11-17-2024, 06:52 AM
  ISO 22762-6: Elastomeric seismic-protection isolators Part 6: High-durability and hig poolmand 0 2,546 11-17-2024, 06:50 AM
  ISO 22762-5: Elastomeric seismic-protection isolators Part 5: Sliding seismic-protect poolmand 0 2,562 11-17-2024, 06:47 AM
  ISO/TS 22762-4: Elastomeric seismic-protection isolators Part 4: Guidance on the appl poolmand 0 2,594 11-17-2024, 06:44 AM
  ISO 22762-3: Elastomeric seismic-protection isolators Part 3: Applications for buildi poolmand 0 2,594 11-16-2024, 01:25 PM
  ISO 22762-2: Elastomeric seismic-protection isolators Part 2: Applications for bridge poolmand 0 2,695 11-16-2024, 01:21 PM
  ISO 22762-1: Elastomeric seismic-protection isolators Part 1: Test methods poolmand 0 2,628 11-16-2024, 01:18 PM
