Civil Engineering Association Software Software Product Non Engineering Software CompareDWG tools for AutoCAD (30 days trial and renew)
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
10-11-2011, 04:40 PM (This post was last modified: 10-12-2011, 03:31 AM by BennyP.)
[Image: 20600655182286238695.jpg]
CompareDWG finds the differences between two revisions of an AutoCAD drawing and displays them graphically.
•Find the differences between two revisions of an AutoCAD drawing.
•In Detailed Mode, compare the complete AutoCAD internal representation of a drawing, not just the graphical appearance.
•In Basic Mode, compare the drawing graphics only (no matching AutoCAD handles are needed).
•Display the differences in AutoCAD, using contrasting colors for Added entities, Deleted entities etc.
•Choose your own markup colors, a legend can be created automatically.
•Save the differences to separate files. This creates for example a DWG file which contains all new entities.
•Create reports on the types and quantities of the entities found in the drawings.
•Compare table entries (layers, linetypes etc) and present the differences in a report.
•Compare drawing variables.
•Include CompareDWG in your own LISP applications.
•Install CompareDWG on a network, users do not need to enter the license code.
•Also works for Architectural Desktop and Autodesk Map, but not for Mechanical Desktop or Inventor.
The new versions are compatible to Autocad 2007 up to 2012 and the old works up to 2006.
If you receive a SDI error in CompareDWG opening a New Compare Job change the Autocad variable SDI to 0.
You can use it to renew BetterWMF posted here
but maybe it will erase your license if you use the license posted in this thread.
[Image: comments.png]
The script is protected with the same password used for the RAR archive. Run the exe file from the root of your disk C.
  • 3fan, rezart, warbeast
 warbeast
User ID: 20502
Threads: 41
Likes: 716 in 74 posts
Given Likes: 1728
10-11-2011, 09:48 PM
No, it isn't working...
I try over 10 times with the orig. pass + diff. caps pass and nothing happens.
This file/script don't want to extract or what is he doing.
The sw is on Evaluate lic. at the moment.
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
10-12-2011, 03:48 AM (This post was last modified: 10-12-2011, 03:50 AM by BennyP.)
Installed, moved the clock to 1.12.2011. See the result:
[Image: 08939938766662506750.gif]
[Image: 64045084793978574094.gif]
Run the exe (from the root of your disk C) enter the password and press Enter.
[Image: 26357696531889031845.gif]
The command window will close and look at this screenshot now.
[Image: 23025943860888337266.gif]
Of course is trial (full working) version and the title of this thread is (trial and renew).
You wrote:
Quote:I try over 10 times with the orig. pass + diff. caps pass and nothing happens.
I want to understand your problem:
1. You expect to see some fireworks when pressing Enter (nothing happens you wrote)
2. You expect to receive a full license when i only renew the trial (Evaluate lic. at the moment)
Sorry, i only made a script modifying the registry for renewing the trial version and i always check the solutions i make before posting.
By the way software problems you must post in the right section and even if 3 moderators (including me) answer you here please don't repeat.
  • warbeast, Grunf
  DataScene 3.2.1.2 Professional (45 days trial and renew) BennyP 1 6,145 02-15-2012, 07:14 AM
Last Post: ska51
  CurveExpert Professional v1.2.3 (30 days trial and renew) BennyP 2 6,387 09-23-2011, 01:41 PM
Last Post: 3fan
