Civil Engineering Association Software Software Product Non Engineering Software BetterWMF 2010 + BetterWMF 4.02
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,705 in 1,304 posts
Given Likes: 4619
10-11-2011, 01:31 PM
Version 2010 (6.00)
[Image: 88316463875924501588.jpg]
Version 4.02
[Image: 13624990786765152607.jpg]
BetterWMF solves AutoCAD problems related to copying and pasting drawings into other software packages like Microsoft Word.
If you have ever tried to insert an AutoCAD picture into for example a Microsoft Office document you may have noticed several problems: To start with, you will get unwanted borders. The resulting size of a picture is the same as the graphics area of the AutoCAD window at the time of creation, rather than matching the selected objects.
This usually means that pictures copied from AutoCAD to other Windows applications will have a large blank area to the top or right.
Also when you print the document with the picture you will notice that all lines will become equally (very) thin.
Finally you will have discovered that it is very difficult to size your picture to an accurate scale.
For each of these problems individual, clumsy workarounds are possible, with varying degrees of success. The real solution is BetterWMF.
With BetterWMF no workaround is necessary: Just load an ARX inside AutoCAD or run Bclipbrd.exe outside AutoCAD and any picture you cut and paste from AutoCAD to another program will be improved on-the-fly.
The resulting picture will be exactly the size of your selected entities. Using the options you can modify the picture in several other ways. For example, you can turn the picture into black-and-white, assign width to the lines based on their color or set a fixed size for the picture as it will appear in other programs. Besides pasting the improved picture immediately into another application, you can also save it for later use.
BetterWMF 4.02 - For AutoCAD R14-2006
BetterWMF 2010 (6.00) - For AutoCAD 2007 up to 2012 and all AutoCAD LT versions
[Image: homepage.png]
Rar file contains both versions of software + Names + serials
[-] The following 15 users Like lisine's post:15 users Like lisine's post
  • foxxx2010, hcardenas, blaze, Dell_Brett, hoanghiepz, warbeast, zrilek, DamaD, malc, ting tsai huang, henrybill, joinsms, melshy2711, melshy2711, tooraj41
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42469
02-21-2013, 08:09 AM (This post was last modified: 02-21-2013, 08:14 AM by Dell_Brett.)
Mirror Link for BetterWMF 2010 only:
BetterWMF 4.02 (For AutoCAD R14-2006)
and
BetterWMF 2010 (For AutoCAD 2007 up to 2010 and all AutoCAD LT versions)
[-] The following 7 users Like Dell_Brett's post:7 users Like Dell_Brett's post
  • knrsa, shadabg, 3fan, Apache, slowet, malc, joker™
