Civil Engineering Association eBooks Structural Books Concrete A DESIGN GUIDE FOR FOOTFALL INDUCED VIBRATION OF STRUCTURES
 gboyega
User ID: 2845
Threads: 33
Likes: 711 in 38 posts
Given Likes: 27
08-25-2009, 09:24 AM
[Image: 6jse0iwvb1mowcfq52a.jpg]
Whilst footfall induced vibrations on buildings or bridges is not normally significant in terms of structural integrity, footfall vibration can be a critical serviceability condition.
This publication presents a new method for evaluating the vibration due to a single pedestrian walking on a flat surface, such as a floor slab or bridge deck. The method was developed by Arup, and has been calibrated and refined with verification measurements taken on completed structures over a period of ten years.
This guide describes a reliable methodology for predicting the vertical vibration induced
by pedestrians crossing structures such as floors and bridges.
Many methods already exist but each of these is significantly limited in some respect.
A full discussion of these limitations can be found elsewhere.
The method presented here addresses all of the issues described below in a consistent
manner:
It is applicable to any type of structure on which people walk, including floors and bridges.
It is applicable to structures of any form or construction material, e.g. steel, composite,
reinforced or pre-stressed concrete or timber structures, and enables reliable
comparisons to be made between designs of different forms and materials.
Complex irregular structures can be assessed as reliably as simple regular ones.
The footfall forcing functions recommended are based on a very extensive set of
measured data, and these loads and the likelihood of their occurrence have been
statistically quantified.
The methodology has been extensively validated and independently peer reviewed.
The method has been used routinely and regularly on design projects around the world
for the past five years, and its accuracy is validated by many measurements of
completed structures.
It interfaces well with modern engineering design methods and software packages.
The method described in this guide is based on the well-established principles of modal
analysis. This enables first principles calculations to be made, and unlike most other methods,
it does not require the introduction of arbitrary or empirical factors. This makes it a robust
approach for the assessment of any type of structure of any construction material.
The method is appropriate for calculating the vibration caused by a single pedestrian
walking on a flat surface on any structure which is significantly heavier (by at least a factor
of 10) than the individual. Whilst very simple regular structures can be assessed entirely by
hand or spreadsheet calculation, it is envisaged that the method will be used principally
in conjunction with finite element analysis as a means of estimating the modal properties
of floor and bridge structures. Whilst this might be seen as an added complexity, in practice
the additional accuracy that finite element analysis of less regular structures brings to the
assessment more than outweighs the modest additional effort associated with building
and analysing a model.
The method was developed within Arup and refined by reference to the measured performance
of completed structures over a period of ten years. It has been independently reviewed by Professor T A Wyatt of Imperial College London.
M R Willford CEng MIMechE
P Young CEng MIMechE
ISBN 1-904482-29-5
Published 2007
Publisher The Concrete Centre
82 Pages
Download Links:
[-] The following 50 users Like gboyega's post:50 users Like gboyega's post
  • concreteok, concreteok, Dell_Brett, Dell_Brett, paulocs, paulocs, nuttapolk, nuttapolk, zrilek, zrilek, rohailiyaz, rohailiyaz, Grunf, Grunf, orambo, orambo, baikur, baikur, ajmf77, ajmf77, mohcivil, mohcivil, timosi™, timosi™, kowheng, kowheng, 713rainbow, 713rainbow, sodapas, salahcivil, toa011, hernansgz, sructme, Trishu999, chenamoy, aleph177, mecheil.edwar, fer962933, triance, vannam200588, Ernest0, ruaumoko, struceng, giga, blaze, albani, RICARDI, smrutigandh.42, Aransam, fbx_rdnk
 timosi™
User ID: 3890
Threads: 143
Likes: 5,532 in 394 posts
Given Likes: 1812
09-16-2009, 01:12 AM (This post was last modified: 09-16-2009, 01:12 AM by timosi™.)
(09-11-2009, 08:29 AM)713rainbow Wrote: Why cannot I download it?
You can try this link:
Mirror link from post #1
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 5 users Like timosi™'s post:5 users Like timosi™'s post
  • 713rainbow, draluka, fer962933, vannam200588, giga
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
02-28-2013, 08:40 AM
[-] The following 5 users Like arshiakh's post:5 users Like arshiakh's post
  • malc, oreslaw, cristi, Aviator, CAMSECT
  Design Guide for Reinforced Concrete Diaphragms A guide to assist design professional sabooryan 2 2,354 02-10-2020, 03:15 PM
  Design Guide for Economical Reinforced Concrete Structures 2016 A guide to assist des sabooryan 1 2,062 01-11-2020, 08:53 AM
  Concrete Durability: A Practical Guide to the Design of Durable Concrete Structures carolinandra 1 2,037 05-01-2019, 03:06 AM
  Blast Resistant Design Guide for Reinforced Concrete Structures Nita1391 2 2,554 05-01-2019, 02:34 AM
  Guide for the Design and Construction of Fiber-Reinforced Concrete Structures ir_71 0 1,974 11-22-2010, 07:32 PM
